Steering wheel shifters (paddle shifters) on CLK 500 only shift up
Old Jun 2, 2015 | 11:14 PM
bennelson972's Avatar
2006 CLK 500
I have a 2006 CLK 500. I've noticed when using the paddle shifters that both left and right paddles shift up. Shouldn't the left side shift down? Can someone tell me how to correct this?
Old Jun 3, 2015 | 12:11 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try resetting the steering column module by pulling fuse #57 (front SAM, panel under the hood) for a minute.
Old Jun 3, 2015 | 09:55 PM
2006 CLK 500
According to the fuse diagram fuse 57 is ESP (electronic stability program)
Old Jun 3, 2015 | 11:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's for the steering column module, which also controls the steering angle sensor. Removing this fuse may mean you need to re-calibrate the steering angle sensor by turning the wheel lock-to-lock half a dozen times.
