Going to lube sway bar bushings...question
To track down suspension noise, you need to lift the car, then use a floor jack on the wheel to articulate it until you reproduce the offending sound. Once you can do that, use a mechanic's stethoscope to pinpoint the source. I thought I had anti-sway bar bushing noise and I did this and discovered it was the bushing on the "lower" control arm (a.k.a. torque strut) where it mounts to the frame.
The control arm bushings went bad and they made a very similar noise, but only when articulating AND turning.
I am now getting some popping/clunking noises from the rear when stopping and starting, so now I'll have something else to look at!
For the rear, you can just buy the bushings so I did that and replaced them and the rear noise is gone as well.
Rudeney's method for the front is definitely cheaper since the new style anti-sway bar with the bushings glued cost me $96 whereas buying just the bushings will cost much less but will require more labour.
Next time they squeak, I am going to order the bushings alone and perform a DIY replacement.
So I ran the rear up on ramps. Chased it around for a while. I would push up on the chassis and grab the different components to see if I could "feel" the squawk. I would shoot some dry lube on the bushings as I went. nothing there.
I finally noticed that it appears that the bushings in the spring links have worn and softened which dropped the spring link just enough to be rubbing on what look like some kind of subframe connectors or something I am not familiar with. (2 flat bars running in a V-shape to the rear below the spare tire area.)
In any event, I put a little pry bar in there to separate the 2 and put some Super Lube between them. No MO Squawk! Problem solved...at least until I can R&R the spring links. Obviously the spring link shouldn't be riding on that bar but it will do for now.
