CLK500 Valve cover gasket Cost$$
Old Sep 23, 2015 | 04:08 PM
stemple37's Avatar
2002 A Class 190, 2005 CLK 500
I have been diagnosed with leaky valve cove gaskets. Oil dripping on exhaust and smoking and burn smell coming into the cabin.
I have have been given an estimate of $400 to replace both sides at an Indy. Is this within line price wise??
Old Sep 23, 2015 | 10:01 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
check around. the parts themselves are dirt cheap, the labor is what gets you
Old Sep 23, 2015 | 10:13 PM
Eojj's Avatar
W209(sold), W212, X204
$40 for a pair of gaskets, maybe 2-3 hours of labor ($50-100/hr)... You could probably get it done for cheaper but $400 isn't horrible if its a reputable mechanic
Old Sep 23, 2015 | 10:16 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
that's a fair price if at a reputable shop. I charge $105 an hour. Yes gaskets are cheap but they are marked up too
Old Sep 23, 2015 | 11:16 PM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
I agree, 400 is a reasonable price. You should also consider opening the breather box covers, cleaning and resealing them as well as replacing all the breather hoses at the same time you have the valve cover gaskets replaced. It will add about 2 hours of labor plus probably 50 dollars for new breather hoses.
Old Sep 24, 2015 | 10:06 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Make sure you use genuine MBZ gaskets. Some aftermarket parts, like Victor Reinz brand, are too thin and will leak. Genuine gaskets are maybe $20 more than aftermarket. As for labor, if the job includes thoroughly cleaning the covers and resealing the breather covers and OEM parts, then that's not too bad. I can do the job in an hour not doing the cleanup or breather covers. Another hour to add those items.
Old Sep 27, 2015 | 09:21 AM
AMG_Adon's Avatar
05 E55
i got quoted 300 by my indy so def can go lower
Old Sep 28, 2015 | 06:42 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
First thing is of course to be sure you need the new gaskets and not just the breathers which was my situation. And as Rodney says cleaning those suckers up is a time consuming pita.
