what do you guys think of this aftermarket head unit?
Old Oct 12, 2015 | 02:01 PM
irokdastar's Avatar
2004 CLK 500
I am looking to upgrade my radio and I found this on ebay . What do you guys think? I have a bose system with cd changer . I know I will lose the cd changer but how about all my speakers ? Anyone installed this before?
http://www.ebay.com/itm/Quad-Core-Android-4-4-Car-DVD-Player-7-GPS-Mercedes-Benz-C-Class-W203-CLK-W209-/321826107392?hash=item4aee54b000
Old Oct 14, 2015 | 08:45 PM
C280 Sport's Avatar
MB’s of all kinds.
I am more of a OEM guy but for a aftermarket system that does not look too bad at all. Check Youtube for videos of how to install and remove the head units.
Old Oct 18, 2015 | 08:14 AM
Simon Johnson's Avatar
W203 C180
I've just installed one today in my W203 C180. Sounds decent, starts up relatively quick
and the touch screen is pretty responsive. Only problem I'm having is I can't figure out how to access Google apps (which it supposedly can do) or get the navigation to start up!
Old Nov 9, 2015 | 12:03 AM
damire's Avatar
2004 CLK500 Convertible
I am about to buy what looks like a similar or the same unit.
How difficult was the installation?
Did you lose any functionality? CD Changer? Radio? Steering Wheel buttons?
Any error codes, etc.
I was debating taking it into a car audio place and letting a pro do it so I am curious if it is something I can handle.
Old Nov 12, 2015 | 06:37 PM
irokdastar's Avatar
2004 CLK 500
Does it sound louder than the stock radio? my issue is if its too low i have to install and aftermarket amplifier which i dont want to do.
Old Nov 26, 2015 | 08:25 AM
Shams Khan's Avatar
2007 CLK550
Same Issue for 2007 CLK550 - Radio Replacement
I am looking to upgrade my stereo to a touchscreen w/ bluetooth - I'm not sure if I have the HK or the Bose system and I believe it is under the fiber optic line but not sure which type (MOST etc). I am willing to get rid of the cd changer (currently I am trying to put in an aux cable and tried to use an FM transmitter) I just don't want to rewire. Can I retain the amplifier the car came with? I would like to retain the same quality sound. I need to play mp3 and be able to use google maps or WAZE even on my phone with audio through the system. And would like have vid capabilities. No need for GPS nav or Phone cap. Any suggestions? Thanks beforehand.
Old Nov 27, 2015 | 11:20 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Your MY2007 CLK550 will have the Harmon-Kardon system using a MOST fiber interface. You should already have an AUX input jack located in the glove compartment on the right side (assuming you have a left-hand drive vehicle - please update your forum use'rs profile with your car and location!)
If you replace the head unit, I do not believe there is any way to keep the factory amp. There may be some aftermarket interface, but I am not aware of anything. You will lose the entire fiber bus, so no factory CD changer, and no TeleAid (mBrace). You will need to run analog audio wiring from the dash to the trunk, then tie into the speaker wires there after disconnecting them from the HK amp.
Old Nov 30, 2015 | 08:55 PM
irokdastar's Avatar
2004 CLK 500
Rodney i just purchased this unit . i have a 2004 clk 500 convertible with the tape and cd changer . do i need to run those cables to the trunk ? also do you know of a wiring diagram for this ? Thank you
Old Nov 30, 2015 | 11:37 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I am note sure if you need to run new wiring or not! Some of those aftermarket systems designed for MBZs actually have fiber outputs so they are plug and play. Check the installation manual. If it does not have fiber audio output, and your car has Bose, then you'll need to run analog wiring.
Old Dec 1, 2015 | 10:49 AM
irokdastar's Avatar
2004 CLK 500
Do you have a wiring diagram of which wI responded to run ?
Old Dec 1, 2015 | 11:13 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Below is a link to the Audio 10 pinout. While this is for the non-Bose system that would have speaker wiring in the dash, I believe the colors of the wires are the same for the Bose amp connector in the trunk.
