all W209 owners, come in here.
CLK63 Black Series
i am trying to compile a list of fun facts, tips and tricks of what all current MBs can do.. i.e. i got this Idea from a BMW forum where they listed all the tips and tricks of their model http://forums.ratedesi.com/viewtopic.php?t=4596
so please give me a list of nifty things you have found out about your car and i will at the end make a compiled list.
2005 CLK 500 coupe
if you press the red and blue temp. buttons at the same time, temp will reset to 72 degrees.
thats the only one I know, so i'll be checking back regularly.
If you apply light pressure to the brake pedal, your front brakes will make a high pitched squeak that will scare off any birds nearby and clear the road for uninterrupted driving pleasure.
2002M3
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
CLK500
Brake squeal
That is one of the most repetitive problems with the W209. If you fight hard enough, the rotors and pads both should be replaced under WARRANTY. There is known problem with the brakes in the front. After I complained 4 times, I got the work done RIGHT, and hence no more scaring the crap out of the birds.
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
I had the same squeak problem...
The front pads and rotors where replaced... and the problem seems to have gone away...
I share the same concern though... can the problem return with the new parts? They are the same as the parts that came with the car...
Originally posted by RJC
Have you had that addressed yet? I'm due for my new pads and rotors next week but I'm afraid the dealer does not know of an upgraded part # for the freaking squeal and I'll end up having the same problem again.
If you hold down the air circulation button, it will close all windows and the sunroof at once.
The trunk will pop back open if you close it with the key inside the trunk. (not sure if this is only keyless go)
btw- is this brake problem common on the 209? I thought I was the only one with this problem.
CLK 270 Avantgarde Auto
Dynometer Mode
With ignition key in position1 and outside temp display showing in speedo screen, press rest button quickly three times. Switches into dyno mode - use up and down keys to scroll thru info on software identity, vin no. instrument no, hardware number, and oil level in litres (switch to ign pos 2 to see values)
Can also switch off electronic aids (ABS,ESP etc ) for use on rolling road only !!
Slk 230 & CLK500
I have had some problems with mine & my dealer has been great. But kind of worried as my dealer changes hands on 3/1/04 from a family run dealership to a corporate one.
03 clk 320
tricks/dyno mode
I tried to change my 03clk into dyno mode, but was unsuccessfull. anyone else? I would like to turn off traction control. will this afffect warranty?
thanks
thanks
