2005 clk ACTIVATE RDS DATA
Also: I can't seem to set the time on my comand unit. The timeset is not highlighted when ignition is turned on. The clock is off by 2 hours.
As for setting the time, if this is a factory installed COMAND, then the clock is set based on the GPS time. You simply select the time zone and then tell it if DST is in effect or not. Press the SERV, then select the TIME button, select the time zone, press the OK button (in on the joystick) then select Daylight or Standard time, whichever is currently in effect. If this does not work, then I suspect you have a retrofitted COMAND and the car has not been properly coded for it.
