Electrical Issues CLK240 Convertible
Is this familiar? Does anyone have advice / things to look at?
2 key issues.
Ignition system failure
Motor failure in HVAC
Expensive issues leaving a bad taste in my Mercedes ownership
Car drove perfectly on 2 test drives and when collecting from the seller. When I stopped to fuel up and re-started is when all the fun began.
Symptoms:
Turn ignition: All dashboard lights go out. Tacho goes off, temperature gauge and fuel gauge turn off. A/C turns off. Seat belt presenter retracts, Windows wont function, Roof wont open or close, Indicators don't work. Fan in engine bay is racing.
Headlights work, radio works, brake lights work.
Car is drivable. Transmission works but wont go into tip-tronic mode. Speedo doesn't work and the odometer doesn't update.
On the list of faults (all of the above were listed on the report, it also lists that all the SRS systems are faulty, ESP is faulty,
I don't have the list of codes. it was over 3 pages on the report. The diagnosis was by an independent Mercedes Benz specialist at Chatswood in Sydney.
2 items to be replaced:
1. Ignition Switch
2. Charcoal filter box with damaged retaining systems and damaged drive gears.
I think I paid too much for this car!!
