After market Chinese radios
Old 06-11-2016, 09:54 PM
CLK280_AUS's Avatar
2005 CLK240 Convertible Elegance Black
Has anyone installed one of these:
Old 06-13-2016, 03:08 PM
jbs04's Avatar
CLK 500
Yes. I have that exact one in my CLk 500. No complaints as of yet
CLK280_AUS (06-14-2016)
Old 06-13-2016, 10:57 PM
irokdastar's Avatar
2004 CLK 500
Yes i have to . Its really great . I have added a front facing camera and rear view camera . One thing though if you have bose or karmen system you will need to get an extension cable to tie into the speakers or get an aftermarket Amplifier . You will lose the oem subwoofer since it only has 4 channels . I added a 5ch amp in the trunk and i used Rcas and ran them to the back .it runs all 4 channels and the subwoofer. If you need help with install let me know i will be glad to help . BTW there is an updated one with Android 5.1 link is below
http://www.ebay.com/itm/231946218958?euid=0c7ed80588434ef2bfa2ee5434ba078d&bu=44099162700&cp=1&sojTags=bu=bu
Old 06-14-2016, 10:22 AM
JimVonBaden's Avatar
2005 CLK500
Do any of these aftermarket radios have GPS that does not rely on Cell Phone data services?
Thanks,
Old 06-14-2016, 10:32 AM
jbs04's Avatar
CLK 500
Thanks,
They all are satellite base so no data service needed.
JimVonBaden (06-14-2016)
Old 06-14-2016, 10:50 AM
TTR
TTR's Avatar
R129 SL500 & W140 S500
So it has it's own built in GPS module? Man that really sucks that it's only 4 channel and you lose your subwoofer.
Old 06-14-2016, 10:53 AM
TTR
TTR's Avatar
How easy is the install and do you need to buy a separate dongle for the steering wheel inputs?
Old 06-14-2016, 12:05 PM
fivesmiths's Avatar
2004 clk320 cabriolet (A209)
I recently put a new system in my car that only supported 4 channels. An easy fix to get the sub back is to buy a mono that will run the sub. In my CLK 320 it was a Bose sub. I used a Kicker 42PXA2001 and fuse tapped it into an open slot on the rear SAM (H/T to Rodney for this one). Since the Bose sub was something crazy like .5 ohm this little amp was perfect. Really small so I lost no space in my cabrio. If you don't want to run all new wiring for power and what not this may be a good option.
Old 06-14-2016, 04:44 PM
2005 CLK500
Good to know. I am considering replacing mine. It is, after all, nearly 20 year old tech, and the GPS is difficult to program.
Old 06-14-2016, 06:45 PM
irokdastar's Avatar
2004 CLK 500
I did a complete system , headunit , speakers , and amp. It was pretty simple to do . I added component in the front 6.5 inch and 2 way for the rear 6.25 . It's better to run the power front the battery just in case there is an issue . You don't want to blow up your sam. It's really easy and simple. Open the hood and remove the battery there is a grommet there that will fit 4 or 8 gage wire fitting through it. You can open it up if you want to put in a 0 gauge . Then remove kick panel ,rocker cover and 2 bolts under rear seat cushion. There is a channel to run the wire through the trunk and your done . Then run your rcas on the driver side . Same way you did the on the passenger side . It lottery took me about an hour to do. If you do a seach on my posts I did a diy . If you got a bit more to spend get some new speakers and 5 ch amp and it will sound amazing . For GPS to work without Internet you will need use offline maps . Some units will come with a memory card and the navigation pre installed . My phone has hot spot so I just use it so I can use waze
Old 06-14-2016, 07:39 PM
CLK280_AUS's Avatar
Hi Irokstar,
I just read the thread on your install. Looks great. Very useful. However my dash is quite different to yours. Mine is a 2005 I assume yours must be 204 or earlier. I don't think mine will fit or look as integrated as yours does.
Old 06-14-2016, 08:23 PM
irokdastar's Avatar
2004 CLK 500
They do make the same headunit for the 05 and up .
Old 06-14-2016, 08:38 PM
irokdastar's Avatar
2004 CLK 500
Here is the one for the 05 and up
http://www.ebay.com/itm/7-Car-GPS-Qu...IAAOSw1KxXMbWM
Old 06-14-2016, 10:19 PM
2005 CLK500
That looks like a great unit. I realize you do not sell these, but do you know if any of them interface with the steering wheel controls, and to confirm, they have GPS capability without a cell phone connected?
Old 06-16-2016, 10:20 AM
jbs04's Avatar
CLK 500
Pretty simple install and I still have all my steering wheel controls.
Old 06-16-2016, 10:48 AM
BigMike62's Avatar
2011 E550 Cab
Is there a wiring harness adapter so that it is plug n play?
Will the steering controls still work with this model?
Old 06-29-2016, 08:50 AM
CLK280_AUS's Avatar
I noticed the ads for the 2005+ models are 260x240x120. My car radio panel measures 254x238x120. anyone had an issue with the panel size?
Old 06-29-2016, 09:24 AM
sailorben's Avatar
CLK W209
Is yours a pre or post face-lift? I've seen a few '2005' cars that are still pre facelift.
Old 06-29-2016, 06:34 PM
CLK280_AUS's Avatar
I am not sure what pre facelift means. My radio fascia has no wood trim surround.
This looks similar, but the dimensions are every so slightly different
Old 06-29-2016, 06:42 PM
CLK280_AUS's Avatar
My radio is similar to this
Old 06-30-2016, 10:51 AM
irokdastar's Avatar
2004 CLK 500
Then you have the face lift. Measure the size of the radio and in the ebay auction it will show you which size is right for you
Old 06-30-2016, 12:30 PM
irokdastar's Avatar
2004 CLK 500
Old 06-30-2016, 12:31 PM
irokdastar's Avatar
2004 CLK 500
This is how to run Wires for a complete system rebuild .
Old 07-01-2016, 09:09 PM
CLK280_AUS's Avatar
Here lies my issue. All of the radios on Ebay are 260x120x240. They even state clearly, :if your radio measures 254x120x238 do not bid on this item.
I guess that rules this option out for me.
Old 07-04-2016, 04:07 PM
irokdastar's Avatar
2004 CLK 500
No email the seller and they will email you the correct auction .
Quick Reply: After market Chinese radios
