Check Engine Light - Purge Control Valve Issue
Old Jun 26, 2016 | 04:08 PM
Leather's Avatar
2004 CLK320
Exclamation Check Engine Light - Purge Control Valve Issue
Hi Guys,
I'm still relatively new to the Mercedes world (~8 months), and am trying to troubleshoot a fault code that's causing my 'Check Engine' light to come on in my 2004 CLK320.
I have an iCarsoft tool that's giving me the following error message:
P2026-004 Y58/1 (Purge control valve) Open circuit/switchover valve permanently closed (P0444)
I've cleared up several fault codes myself, all electrical stuff that I was happy to replace. But this one has me stumped.
I searched around a bit, but it appears the solution varies from situation to situation.
Anyone have any suggestions on where to start? Should I look for an indy to take a look at this?
Old Jun 26, 2016 | 06:01 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's under the hood, left side, between the ESP control unit (where all the brake lines come in) and the fender. It looks like a small motor (which it is):
Old Jun 27, 2016 | 10:35 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Technically, it's a servo (which is a type of motor), but it does just activate and not "rotate".
Old Jun 30, 2016 | 01:53 PM
Leather's Avatar
2004 CLK320
Thanks Rudeney and Plutoe for your replies. The check engine light disappeared on its own. My iCarsoft reader says that the error is stored in the history, but not active anymore. I know sometimes these faults can come and go.
If it returns, I'll be using the image you provided to give this a quick look myself, and will likely stop by my mechanic to get his opinion.
I'll update this thread if anything else happens. Thanks guys!
Old Jul 3, 2016 | 03:03 AM
mrwhattie's Avatar
2005 ML 270 CDI, 2004 E270 CDI, 2006 CLK55 AMG
Hi everyone,
I am having similar problems with my purge valve as well (clk55amg). I find it mostly happens when I fill up the tank. Is this valve some kind of breather for the fuel tank. Will I need to remove the fuel tank to replace the valve? or is it easily reachable inside the rear wheel arch as I seem to recall someone mentioning this a while back. The check engine light sometimes goes off after a while, but it still worries me while its on. Which part is most likely to be at fault, the valve by the tank or the solenoid in the engine bay.
Old Jul 3, 2016 | 09:04 PM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
The strict rule is NEVER top up your gas tank. When the pump clicks off, that's it.
Old Jun 19, 2024 | 01:06 PM
germancampero's Avatar
ML350
Arrow
Originally Posted by mrwhattie
Hi everyone,
Hi there, I know its been quite a while since you post this here but, by any chance could you solve that issue? Im having the exact same experience with my 2007 ML350. Every time going for a refuel, not even topping up, just half a tank, suddenly while driving back home, check engine light pops, and same code: DTC 0851: Purge control valve: opencircuit/switchover valve permanently closed (P0444). How did you solve it?
Old Jun 19, 2024 | 02:20 PM
Leather's Avatar
2004 CLK320
@germancampero I'm the original poster of this thread, and in my case, the purge valve just needed to be replaced. My mechanic did it for about US $400 total but keep in mind this thread is 8 years old. Prices have increased a lot since then.
