w209 rough shift
Old Dec 14, 2016 | 09:02 AM
a.keen97's Avatar
2007 CLK 350
w209 rough shift
I know there are a few threads that reference this issue but I haven't seen any specifics on where to proceed. I recently purchased my car, 07 clk 350, for a great deal, but with a limited service history. It has rough shifts from time to time when slowing to a near stop, etc. They are not terrible, just enough to notice a lag. I have never gone into limp mode nor experienced any other issues. 99% of the time the car shifts flawlessly. I wanted to know if you thought this was something I should have checked out or if it is just the nature of the vehicle/tran (from hat I have read, I assume the latter). I had read that maybe a tran update may fix this, but others said even after replacements and re-hauls, there is going to be a rough shift 3-2, 2-1. If an upgrade is a possibility, does anyone know the most recent available update and somehting I could reference by as the dealership seems to write off the thought of an update immediately. I'm very thankful for your knowledge and appreciate your time.
Old Dec 14, 2016 | 09:23 AM
BenzAMG99's Avatar
C63s
Are you warming up the car before driving?
Old Dec 14, 2016 | 09:57 AM
a.keen97's Avatar
2007 CLK 350
Not necessarily, but even after being driven for a half hour or more, this rough shifts tends to happen periodically.
Old Dec 14, 2016 | 11:51 AM
Reanimation's Avatar
270 cdi w209
If you have the money book it in for a gearbox service since you say the service history is limited, I bet the down changes improve. What mileage?
Old Dec 14, 2016 | 10:16 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Your transmission needs a fluid and filer change (including torque converter drain) ever 40K miles. If this is a "clunk" when it downshifts from 2-1 as you are coming to a stop, then this can be solved with a firmware update to the TCU. Basically, they delay the 2-1 shift until you are fully stopped. It will cost about an hour of labor time at the dealer to do this. If you also need a fluid/filter change, you may get get them to do it as part of that service - usually around $450.
Old Dec 15, 2016 | 07:18 AM
a.keen97's Avatar
2007 CLK 350
Thanks all! Rudeney, do you have any specifics that I could reference the TCU update by? Dealer just says "it's been a while since an update for this Rena's has come out and I'm sure your car, being 10 years old has already received the latest one." They want to charge $200 just to search for an update, which I think is ridiculous. I'm going to go forward with a train service, hoping maybe if I had specifics on firmware I could lump that in, without them having to "search".
thanks a lot all
Old Dec 15, 2016 | 12:21 PM
xsever's Avatar
2012 C300 4MATIC Sport
thanks a lot all
If someone here on the forum has a W209 with the 7-speed transmission and access to SDS, they can use the latter to read the firmware version of the TCU and post it here.
I have an SDS, but my car has the 5-speed not the 7-speed.
Good luck!
Old Dec 15, 2016 | 09:53 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'm can't find the TSB, but there was definitely a software update that solved the clunk when slowing to a stop. I'd find a different dealer, or at least someone else at that dealer to talk to about it.
