How does average mpg calculation work?
I really like the "From Start" statistics, especially how they are reset automatically. Haven't seen that on any other car.
%age of WOT TPS input plus airflow through MAF = injection rate trimmed by measurements from the O2 sensor.
gaping hole in the data calculation, i opine, as that simply returns fuel used
and no one has yet mentioned (or take into consideration) miles traveled.
oh, I see that Anker implied mileage in his response vis a vis 'from start'
so, if the programmers are worth their salt, they would cross check the data
as well as utilize other sensor metrics not limited to MAF, intake pressure,
fuel remaining in tank, odometer, etc.
MPG is a moving target depending on a variety of conditions (cold, warm,
pressure, throttle position, current MPG, current tankful MPG, etc) that the
designers can program the results to average this based on a preset palette
of conditions.
The ECU knows exactly how much fuel is being injected for a specific throttle opening & fuel trim. (caveat no leaking or damaged injectors).
But I'm with you.
When I fill from the exact gas station standing in the exact same spot, the mileage the app gives me and the "From Reset" dash display are exactly the same. (I reset the mileage at each fill-up). The accuracy is really perfect.
When I fill from a different gas station and/or with different inclinations, then there is some variance.
So this leads me to conclude that the programming on MB's side are pretty accurate.
And especially if you do any hard acceleration under open loop conditions. But it does teach one when running downhill to take your foot right off the gas to shut off injection completely. Then the numbers come tumbling down.
On a 130mile journey, traffic was very congested, but managed to keep driving along at about 45-50 most of the way home. After about 60 miles, I achieved 60.2mpg! Not a typo! As I was coming closer to home, I got into the country lanes so had to get that screen off, after having 20 mins of fun it was down to 50mpg. Pretty outstanding.
Usually at 70mph I get 45mpg which is decent. My 45 minute commute to work has a mix of city and 15miles of 70mph, I average about 38mpg. I have to have the consumption screen on, as otherwise if I'm not careful I can quite easily get the consumption up to 30mpg without much issue. Which for a diesel is rubbish.
