Instrument cluster won't turn off
Have you solved your issue or has anyone else out there have a suggestion ?
In this case, it might be worth spending, say $100 for a used cluster to temporarily install it and see if that fixes the issue. You can't keep the used cluster in place as it will negate your odometer, but at least you can see if it shuts off. If not, you know the cluster is not the culprit. If it does, then you need a new cluster (or, someone with the skills and tools to zero the odometer on the used cluster, and the tools to "marry" it to your car).
@Russell: If circuit 15 were not shutting off, then the ACC unit would stay on, too. And the wipers would work with the key off.
Cleaned connector and replaced Sam. All is good now.
I have a 07 ML350 . After leaving the car. Dash light will come back on and all the idiot light will flash on every 10 seconds.
if you pull fuse 55 or 54 it will stop.
Root cause water and corrosion in front Sam under passenger seat
I tried a few random things, but I hit the brakes twice firmly and it went out!
When I got out and locked the car, it was the last to go out, about 30 seconds after the tail lights/headlights (I have them set to stay on for a bit)
