Discovered strange leak
Old Jul 30, 2017 | 03:06 AM
Ghennes13's Avatar
2009 CLK550 Coupe
having a strange leak coming from the driver side in front of rear wheel. Happened out of nowhere. Can't tell if it's hydraulic fluid or transmission oil. I will say that the previous night I put the convertible top down but didn't have any malfunction. Next day discovered this. Anybody have this issue? My car is a 05 clk320.
Old Jul 30, 2017 | 10:02 AM
Yidney's Avatar
2008 CLK550 Cab
The obvious first step is to check the fluid level in the top reservoir. If you don't know how, in your trunk on that same side there is a door on the side maybe 5" wide and 8" tall in the black fuzzy side panel. Pull it off. The reservoir will have a clearly marked "Full" line.
Old Jul 30, 2017 | 03:11 PM
Ghennes13's Avatar
2009 CLK550 Coupe
I checked the level. Level is low. Where is it leaking from?
Old Jul 30, 2017 | 06:55 PM
Ghennes13's Avatar
2009 CLK550 Coupe
Found the culprit. It's a cracked line. Sprays everywhere! It's the number 22 line that connects to this cylinder. Now just need the part number .
Old Jul 30, 2017 | 09:59 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Which cylinder is that?
Old Jul 30, 2017 | 10:13 PM
Ghennes13's Avatar
2009 CLK550 Coupe
Driver side bow tension cylinder
Old Jul 30, 2017 | 11:38 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The part number I found in EPC is A2098000881, but I don't think that's right as it is noted for use with the auto trunk opener. You might ping Klaus at Top Hydraulics - he sells some hoses, too. If you go to the dealer, they should be able to give you the correct part.
