CLK55 Loss of Power Steering Fluid
Old Aug 26, 2017 | 02:09 PM
breeze247's Avatar
W209 CLK55 - 2003
I've just lost what looks like all of the power steering fluid on my 2003 CLK55. Complete loss of steering assistance and the undertray has pooled a lot of fluid.
Before I can get somebody to take it apart, is this a known issue with a known fix?
I am thinking pump, lines or cooler (if it has one).
Any experience gratefully received!
Old Aug 26, 2017 | 03:35 PM
breeze247's Avatar
W209 CLK55 - 2003
Sorry - to add, the loss of steering was sudden. From memory, it may have been at a point where the steering was turned fully in one direction.
This is making me think that a seal blew out somewhere or a damaged hose finally gave up...
Old Aug 28, 2017 | 12:00 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Sudden loss is probably a blown hose or connection of a hose. Slow leaks are usually bad seals in the rack.
Old Aug 28, 2017 | 02:55 PM
breeze247's Avatar
W209 CLK55 - 2003
It was one of the hoses in the end. I had the garage do a temporary repair but will need to buy the replacement part.
It was part 160 in the attached, right next to the part on the diagram marked 170.
Old Aug 13, 2018 | 02:56 AM
Dbenzboy's Avatar
Clk
Unhappy Steering fluid leak
what if the inside boot have fluid , will this cause of fluid entering the boot came from the blown hose or there is a seal inside boot that is leaking .?
Old Aug 13, 2018 | 03:00 AM
Dbenzboy's Avatar
Clk
is there a seal kit for the driver side boot .?
