Headlight marks - See Photo
This is the passenger's side headlight. 2009 CLK350.
What would have caused this? Has anyone seen this before? It's not really noticeable to others, but it bugs me!
I am assuming I'll have to replace the headlight.
The light output is identical to the other light.
Any ideas/comments welcomed!
Thanks!
blackduc1
If it is outside, you could try a clear plastic cleaner/restorer. I have used a cleaner from Meguiars (not the polish) to effectively keep the lens clear. It takes some elbow grease but I was very pleased with the result. I sprayed a little on the lens and rubbed it quite hard with a microfiber cloth draped over a rubber sanding block. With the discoloration in those grooves you may have to use a thick wooden toothpick or the edge of a thin plastic scrapper or putty knife (plastic). Just make sure you cover the tool with a microfiber cloth.
I took the lenses off of my W-210 E320 Sedan, and it was difficult. The plastic mounting bits tend to be very brittle and If you lose one of the tabs on reassembly, you won't have an even seal all the way around the lens.
I'm going to look for the thread you mention and see what I can find out. It's not noticeable unless you are looking for it...or as my wife says; It's not noticeable to 'normal' people... lol!
I have a rare Saturday to myself, so I am planning a car day to give my new girl and good wash, clay bar, etc., so I'll take a closer look at the light and see what my options are.
Thank you Fatz!
blackduc1
You have to be extremely careful not to touch the chrome on headlights. It comes off way too easy. To the point that anytime I bake headlights the reflector/chrome pieces immediately go into a bag so that no dust or crap can get on them. I made the mistake once of trying to clean a small water spot off the chrome and it wiped off the chrome completely. Only wear nitric/latex gloves and never handle with bare hands because the oils from your fingers will get on them.
You are probably getting moisture in the headlight and then when the headlight is on it's baking them which is causing the chrome to lift/peel. Give it more time and more will eventually chip/peel...lol
Have you noticed your headlight being foggy/hazy after a rainy day or humid day?
-Nigel
-Nigel
Thanks for the explanation and warnings! I've been told about the chrome coming off very easily, and I'm one of those guys that would have tried to 'polish' it up before putting back together...I would have ruined a light!
I haven't noticed condensation, but I haven't had the car that long. I'm going to get into it on Saturday and evaluate my options.
Appreciate the advice and direction!
Best,
Rick
