Headgasket Help
1. other than the wrecker, are there trustworthy sites where I can buy a used engine. I haven't tried LKQ yet. I was forwarded some links that had m113s for around $500 depending on the mileage?
2. What's a good price for the labor on an engine swap? I've heard $1000
3. Are there any other pitfalls I need to look out for? Other things that need to be replaced besides the engine (possibly the cooling system since its contaminated)
Advice and suggestions are much appreciated. Thanks.
once the car is warmed up you can put your hand behind the exhaust for a couple of seconds and then smell it. If its a sweet smell at all thats coolant.
Would the car run hot if it were the head gasket? I've driven the car out of necessity and have observed normal operating temperatures. A mechanic told me I could keep driving it until it got hot. I figured if it was the head gasket, then the engine was gone anyway.
Picture attached of the oil cooler yours will just be on the other side of the oil filter housing.
http://benzbits.com/m112/OilCooler.pdf
If it is engine oil you really may have a slow headgasket leak. After how many miles do you need to top up the engine oil ?
