BORE SIZE
BORE SIZE
FRONT: 8.5 X 18 H2 ET 25
REAR: 9.5 X 18 H2 ET 28
These wheels are off a W219 CLS
i would like to put them on a W209 2003 CLK500
which has this wheel as OEM
The OEM have a 32 ET front / 37 ET rear
Both wheels (W209 / W219) are 5x112
I have searched for the bore size of the W219 wheels
but have been unable to find the answer to see if it is the same
as the W209 OEM wheel bore size
I would be mounting the following size tyres
Front: 245 x 40 / 18
Rear: 285 x 35 / 18
My question(s) is - is the bore size the same for W219 / W209
and will these W219 wheels / tyres work on a 2003 W209 CLK500
Thank-You
D.B.
Rear: 285 x 35 / 18
Thank-You
D.B.
I think MB uses a standard bore size. Can't swear to it, but I think so. If you like that style, why not get a set off a CLK550 from 08 or 09? Same style spokes. They will have a closer offset to your original. The outer part is slightly different. The lower offsets on the ones in your pics will makes those wheels sit out a bit - like if you put 10mm spacers on your current wheels. You'll have decide if you like that look.
Looking for the wheels/tyres to stick out
I'm an old man and I like the look- 50's/60's retro look
Now the problem may be the wheel bolts as I found this:
"All mercedes bolt patters are 5x112 but that's the bolt pattern. The sizes of the seats on the bolts are different. Cs, CLKs, W210 E classes and SLKs use a 12mm wide bolt, where as CLS, W211Es, SLs, etc... uses a 14mm bolt. So if you use the 12mm bolt on the rims designed with the 14mm bolts, there will be 2mm gaps around the bolt and it's not exactly safe."
Are the thread sizes the same - just the head of the bolt is different?
Would obtaining the correct W219 CLS wheel bolts from the dealer work
Dazed and confused without smoking pot
Thank-You
D.B.
Thank-You
D.B.
I am being told that I need these bolts for the W219 CLS wheels to fit properly:
http://otisincla.com/product/12mmx1-...h-zinc-plated/
Thank-You
D.B.
Thank-You
D.B.
I have bought Otis bolts in the past, had them torqued properly and some of them snapped over time....just a thought. That being said, they're supposedly the best, though I've had better luck with ebay bolts so far.
Bore size - should be the same, otherwise get hub centric adapters.
Bolt pattern - should be the same, on the same car make.
Type of bolt - Conical/Ball seat. This is based on the wheel and how the actual holes for the bolts are made. If the CLS uses conical bolts stock then you need conical bolts.
Size of bolt - This is based on your car. If your stock bolts are M12, then you need an M12 regardless what wheels you put on. The only thing that might change is the length of the bolt, based on wheel design. You want to make sure the bolt threads into the hub enough to hold the wheel and not stick out on the other side of the hub, possibly damaging components.
Offsets - I would look for somebody who has the same wheels on a CLK to get a clear idea on how exactly they will look.
Does the W209 2003 CLK500 use conical bolts or ball
Does anyone know if the W219 CLS wheels are conical or ball
I really appreciate the knowledge being shared in this thread
Thank-You
D.B.
Thank-You
D.B.
Found out the W219 CLS wheels use a conical bolt
The W219 CLS wheels have the tire pressure monitors
inside the wheel - since I won't need them on a 2003 CLK500
can they be removed or should they be left in place
Thank-You
D.B.
Found this: http://www.imgrum.org/user/clk_drive...6828_646091704
Thank-You
D.B.
These pictures show a 2003 CLK500 with CLS wheels
No spacers
The CLS wheels are 8.5x19 F / 9.5x19 R
It said they are the same offset as the ones i'm looking at
Again - I really appreciate the input I received from
the forum members who posted
Thank-You
D.B.
No spacers
Thank-You
D.B.
