Are they Worth it?
Old Feb 12, 2018 | 11:45 PM
NotAMechanic's Avatar
BMW 530i E60
Question Are they Worth it?
So I'm about to close a deal on a 07 CLK 350 and i wanted to know what your guys' experience has been with this model. Are they Reliable? Hard to Maintain? Also, does the convertible top malfunction often? and if so, is it expensive to get it fixed?
Old Feb 13, 2018 | 12:57 AM
xsever's Avatar
2012 C300 4MATIC Sport
You want to avoid half the MY2007s as they can experience engine timing chain idler sprocket (a.k.a. balance shaft) failure. You also want to avoid any 722.9 transmission prior to MY2008 since they experience conductor plate and fuel pump failures.
You can post the car's VIN here so we check if the engine is in the range of the idler sprocket failures, but the general advice here is stick with 2009 or 2008 CLKs since by then all of the problems were ironed out.
Old Feb 13, 2018 | 01:01 AM
BMW 530i E60
The Vin number to it is WDBTK56F37T080367
Old Feb 13, 2018 | 01:40 AM
xsever's Avatar
The engine serial number is 30-504583 which is beyond the range of engines affected, but you would still have the transmission problems to worry about. Are you able to know from the seller if the transmission has been serviced/repaired so that you don't inherit these problems?
Removing the transmission to replace the conductor plate and/or change the fluid pump, which will require a live connection to MB's servers to reprogram the transmission control unit, will prove to be very costly if you live in the US or in any country where labour is not cheap. We are talking $1-3k here.
