Passanger door has not electric ( mirror-window-seat not working )
Old Feb 27, 2018 | 04:37 PM
alpsea's Avatar
2002 CLK320 AMG - W209
Hello dear forum members. I have big problem. Right (passenger) door switch isn't working. Mirror-window-seat-lock.
All fuse well done! Switch hasn't light.
Try Battery (-) out after i wait 15 minutes. It's not worked.
Please help me! What is the problem?? DCM? Lock module ? Battery changed in a month.
The seat pull is moving head. Seat's electric active
Old Feb 27, 2018 | 10:30 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Check fuse #22.
Old Feb 28, 2018 | 07:02 AM
alpsea's Avatar
Originally Posted by Rudeney
Check fuse #22.
Fuse 22 and all fuses active..
Old Feb 28, 2018 | 08:51 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I might be a bad door controller. I'd get a proper diagnosis and pull codes from it.
Old Mar 1, 2018 | 07:35 AM
alpsea's Avatar
Test obd 2. Door control module fail ..
Old Mar 1, 2018 | 09:00 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, I think you need to replace the door controller then.
Old Mar 2, 2018 | 07:26 AM
alpsea's Avatar
Is it possible to repair ?
Old Mar 2, 2018 | 09:54 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I seriously doubt it. I am sure there are some electronics experts out there that may be able to do that, but for 99.999% of the rest of us, we replace the module.
