Oil Change
The magnets came in a kit with the oil cooler gasket and a Mann oil filter. The filter came with 5 o-rings. I found a spot for 3 of them. Are the other ones for different cars?
Also when I took the oil filter out it was just sitting in the housing. Seems like it was the completely wrong one put in. The oil change reminder sticker said Canadian Tire. That worries me a little. Good thing it was just done in December and was only driven a few hundred km.
The oil looked fairly clean, but does anyone think that the non-filtered oil may have something to do with the engine throwing the P0025 code?
Also, is the oil cooler gasket a common thing to change? I didn't do it because it looked like a Bit*** to get in there. I can't even put my hand between the fan and rad.
So I've got everything changed, but I haven't fired it up yet. waiting for tomorrow.
I do not know what the P0025 code refers to. I would have to look it up. But I had my oil cooler replaced because it leaked at about 125K miles. There was no error code associated with the failure.
http://benzbits.com/BalanceShaftTSB.pdf
The solution is to replace the camshaft solenoids (magnets) with the revised parts. But, there are a handful of reports I've seen in the forums where the errors return even with the new parts. I suspect they may have had a batch of bad new parts. Or, as Kevin suspects, it could be an oil issue since the adjusters themselves are hydraulically operated.
In case anyone needs it, here are the generic OBDII "P" codes and which solenoid they refer to:
http://benzbits.com/M272/CamshaftSolenoidCodes.jpg
It's been a couple of days since I changed the magnets, cold idle seems to be better, but other times it is a little rough. Once off idle it is smooth as hell with no signs of miss at all.
Maybe a person can't expect a digital controlled engine to run as smooth as one with a carb? Or is it because it is a high compresson engine?
Either way it runs just fine and has gobs of torque. No CEL in the first thousand km.
high in titanium 385 ppm and high in glycol 0.0109%
The sample company said titanium is being used in some oil as an anti wear additive.
I am not 100% sure what make of oil the car had in it when I got it, but I put in Mobil 1 0W40 Euro Spec.
There was no sign of lead, or iron, so I am happy. The glycol might be the gasket in the oil cooler/filter
assembly (hopefully) I took another sample of oil right after changing it, so that will be the baseline of
my EuroSpec oil.
Any thoughts from the crowd?
But something odd. My indy changed out my oil filter housing and cooler, but in the process changed the drivers side magnet. I was getting P0021 and P0022 at times and now it is gone. He said the magnet was "stuck" even though it was the updated part. I'm still getting P0012 on the passenger side along with P0011 now. I ordered a new magnet for that as well (and nothing blocking it from changing it myself). Note both my intake magnets were changed at the same time and they both had the first two digits as 14 (I assume meaning 2014) on the front plastic side of the magnet. I'm wondering about as Rodney said earlier about there being a defective production with the updated part at some time few years back.
I've seen about a dozen or so instances of this even after the magnets were changed to the revised parts. I think in all cases, at least where the forum member posted a follow-up, replacing magnets fixed it.
The P0021 and P0022 have not returned since. I just changed out the passenger side intake one myself since it was throwing P0011 and P0012 codes. The magnet even though updated was definitely not smooth the little metal pin inside and was getting stuck. I replaced with a new and cleared it and it's all good so far. I checked and both my old ones had the digits 14 stamped on the front (I assume meaning 2014). It is very likely now that there indeed was a bad batch. I would recommend for others having repeated issues to check theirs out and just replace again.
https://mbparts.mbusa.com/oem-parts/...sor-2721560000
