Comand Unit buttons stopped working
Old May 22, 2018 | 02:12 PM
RobertCLK320's Avatar
CLK320 CDI
hello all,
The buttons on the Comand Unit (satnav/cd/radio/telephone) stopped working all together from one day to the next. The screen works, the radio and phone still work and I can operate them via the buttons on the steering wheel. However, none of the buttons on the unit work. Has anyone else had this before or could give me any tips on what it could be? My car is a UK 2007 CLK320.
Many thanks in advance.
Old May 22, 2018 | 10:06 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try resetting it by pulling fuses. Also, I think you can hold down the power button for some length of time (30 seconds?) and it will reboot. If none of that works, then it may be an internal fault inside the COMAND unit.
Old May 23, 2018 | 03:42 AM
CLK320 CDI
Thans you, I’m going to try that and let you know if it worked. Cheers
Old May 29, 2018 | 03:22 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
IF your buttons are killed by spillage it only takes a few minutes to swap out the face plates.
I got one lying around somewhere if you need one.
Old May 29, 2018 | 03:45 PM
CLK320 CDI
That is very kind of you thanks! Unfortunately it wasn’t due to spilling anything.
Old May 30, 2018 | 08:46 AM
Johan_vn's Avatar
ML350 BlueTec W166 - C250d W205 - GLC250d - C43
Hi, sorry to come in on a tangent like this, some of my buttons on the COMAND are scuffed and worn, can you replace the buttons on the unit (sounds like that's what you meant?) and where can I buy them. Thanks in advance.
Old Jun 27, 2018 | 03:21 AM
CLK320 CDI
They work again!!! It’s a miracle. Radio still worked and wouldn’t switch off after I locked the car. Pulled the radio fuse out and back in and all the buttons work again! Happy days
