P0015 - can magnets be replaced one at a time?
Old Jun 9, 2018 | 02:19 PM
Fathom39's Avatar
CLK 550
I have two new magnets but want to replace only one right now because of time and convenience. Will replacing only one of two (or even four) magnets cause problems?
I want to start on the left side (bank 1 per P0015 description) with the easy one first. On the M273 engine the second one is behind the oil cooler which with my big hands and arms might require me to remove radiator cross-member support and radiator top hose to get access to the bolts for the oil cooler. Then, I will need to order a gasket for the oil cooler and might as well get a new top coolant hose which looks like a tricky clamp connection at the radiator. So, while the first magnet will be easy to replace, the second one will take much longer.
2007 CLK 550
Old Jun 9, 2018 | 05:41 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes. But the dealing with the oil cooler only takes maybe an extra hour, if that. Just get a new gasket for it.
Old Jun 9, 2018 | 09:16 PM
Fathom39's Avatar
CLK 550
Thanks, Rodney.
FYI to anyone else in the future:
- Right side is bank 1
- Left side is bank 2
- P0011 and P0012 indicate RIGHT side intake
- P0014 and P0015 indicate RIGHT side exhaust
- P0021 and P0022 indicate LEFT side intake
- P0024 and P0025 indicate LEFT side exhaust
0059 Continuous camshaft adjustment ( RIGHT ): Incorrect position of the exhaust camshaft (P0014)
0060 Continuous camshaft adjustment ( RIGHT ): Incorrect position of the exhaust camshaft (P0015)
0063 Continuous camshaft adjustment ( LEFT ): Incorrect position of the exhaust camshaft (P0024)
0064 Continuous camshaft adjustment ( LEFT ): Incorrect position of the exhaust camshaft (P0025)
0271 Continuous camshaft adjustment ( RIGHT ): Incorrect position of the intake camshaft (P0011)
0272 Continuous camshaft adjustment ( RIGHT ): Incorrect position of the intake camshaft (P0012)
0275 Continuous camshaft adjustment ( LEFT ): Incorrect position of the intake camshaft (P0021)
0276 Continuous camshaft adjustment ( LEFT ): Incorrect position of the intake camshaft (P0022)
Old Jun 9, 2018 | 11:01 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
The magnet and sensor behind the oil cooler and radiator elbow are for the intake of bank 2. I just changed magnets and sensors for bank 1 and the exhaust magnet and sensor for bank 2. Did not change the intake magnet and sensor because the 2 vertical screws for the elbow were damaged (Indy). I have the screws now and the gasket for the elbow and the oil cooler, but since they were changed at 50K miles I may not change them right now. They are working ok. The exhaust magnet and sensor for bank 2 can be changed w/o removing anything else.
Is it your intake for Bank 2 that is showing an error?
Old Jun 10, 2018 | 09:58 AM
Fathom39's Avatar
CLK 550
Thanks, Fatz. I'm new to M-B and I mistakenly assumed "bank 1" part of the generic P0015 description meant the left side. Then I learned bank 1 is where cylinder 1 is located and for M-B this is the right side. Then, I found a post from Rudeney some years back where he mapped each of the eight codes to their location. So, I lucked out with P0015 because it is the easiest to reach of the four magnets. Job all done now.
Old Jun 10, 2018 | 11:02 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Note that when talking about "right" and "left" in a car, it is always relative to sitting in the cockpit looking out the front windshield. So, then standing in front of the engine with the hood up, the "right bank" will be on your left.
Here's the diagram you mentioned, from the perspective of standing in front of the engine (so left is right and right is left!):
Old Jun 13, 2018 | 08:03 AM
TechSuperstar's Avatar
15' CLS400
2007 CLK 550
Not sure how different the 273 is from the 272 but I was able to replace mine without removing the oil cooler or PS reservoir. Just get yourself a small 1/4" combination wrench. It will fit onto the torx head. Remove the sensors first to give your room and be careful not to strip the head (but if you do vice grips and an new bolt work There is a video on youtube somewhere showing how to do it with a wrench.
Old Jun 13, 2018 | 04:27 PM
Fatz's Avatar
The WIS I saw also did not indicate that the oil cooler or coolant elbow needed to be removed to replace the magnets or sensors. It did reference an H-8 tool however. I believe this is similar to a crows foot attachment used to get into tight places. I didn't have one, and the torx screw sockets were too deep to use to remove the fasteners for the coil and sensor related to P0021 and P0022 in the drawing from Rodney. I will try one day during the winter, using a small ratcheting wrench.
I think for now, because that magnet and sensor are ok for me and the OP, we're good. I'll try to remember to follow up on if the wrench or shallow 1/4 inch socket woks on the 273. Thanks
Old Jun 13, 2018 | 10:00 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
When i replaced them on my CLK550, I was able to remove the bolts on the sensor, but the sensor itself did not have enough clearance to remove with the oil cooler in place.
Old Jun 24, 2018 | 04:31 AM
Kelvin Bellrose's Avatar
2007 CLK550 Coupe, 2003 CL600, 2012
I replaced all 4 on my 07 clk550 without removing anything else, just unplug all the sensors in the area. The one behind the oil cooler was real tricky, but it just slid out with half a mm of clearence.
Old Dec 16, 2019 | 08:37 AM
JayDV's Avatar
CLK 350
I'm a year late to this party buy I also have P0015 and P0025 codes. Sounds like I need to replace these "magnets." If anyone can help with part numbers and/or recommend an on-line store to order from, I'd appreciate it...
Thanks!!!
Old Dec 16, 2019 | 10:55 AM
Thanks!!!
FCP EURO Has the kit with all 4 in it.
Old Dec 16, 2019 | 11:08 AM
JayDV's Avatar
CLK 350
Thanks! I visited the site. Searched "magnet." Site doesn't seem to recognize the item. Any further help would be appreciated...!
Old Dec 16, 2019 | 12:21 PM
https://www.fcpeuro.com/products/mer...ercedes-515811
Old Dec 16, 2019 | 12:23 PM
JayDV's Avatar
CLK 350
Got it...THANK YOU!!!
Old Dec 20, 2019 | 04:21 PM
JayDV's Avatar
CLK 350
Got Bank 1 done...Easy-Peasy! On to Bank 2 (left side). Besides the oil cooler contraption, there's another reservoir of some sort. Black with a cap on it. At first, I thought to just loosen the 3 torx bolts and it would come off. Well...
The f**kin' thing just won't come off! Kept looking for another bolt (all 3 completely loosened) and couldn't find anything. Shoved a mirror underneath and didn't see anything. Gently twisted and pulled but still no result. The most frustrating...the ONE magnet screw is RIGHT THERE but I can't get to it!!!
Any help would be appreciated!!!
Old Dec 20, 2019 | 09:11 PM
nkx1's Avatar
2010 E550 Coupe
Interesting- maybe this is a job I can do myself then. Can you elaborate on unplugging sensors?
Old Dec 21, 2019 | 08:30 AM
JayDV's Avatar
CLK 350
On my '07 CLK 350, just release the clip (slide it up) and pull the sensor off the magnet. After that, it's a simple matter of taking off the 3 screws (1/4" socket), taking out the magnet and replacing it.
BTW...still looking for some help with getting the reservoir out of the way on the left side. Any suggestions would be appreciated!
Old Dec 21, 2019 | 05:21 PM
JayDV's Avatar
CLK 350
**UPDATE** For those following, here's some further information on the magnet replacement project:
1. Started with check engine codes P0015 and P0025...Cam solenoid (magnet) failure;
2. Took Kelvin's advice and order a kit from FCU EURO. $125 with tax and shipping. Four magnets plus oil cooler filter and gasket. Prompt delivery. VERY helpful in providing installation instructions and communications via e-mail;
3. Bank 1 (Passenger side) replacement easy peasy! 1/4" socket was all that was needed on torx shaped bolts. Old solenoid out; new solenoid right back in;
4. Bank 2 was challenging. Bottom bolt on both magnets tucked behind oil cooler and power steering reservoir respectively;
5. Tried to remove both components so I could access the bolts. What a pain in the ***! Just couldn't do it without spilling lots of fluids, especially power steering reservoir;
6. Checked out YouTube and found a video in which a guy used a !/4" box wrench to slip behind both the oil cooler and the reservoir and was able to grasp and loosen both of the bolts;
7. It was very helpful to detach the solenoids as well as take off the power steering reservoir cap to make for a little easier access;
8. Old magnets out; new magnets in. Just a little challenging to hand screw the bottom bolts but, once in, was able to use the 1/4" box wrench to tighten.
Thanks again to everyone for your input and help!
