05 CLK500 - Car shakes hard when coming to a stop? Possible faulty new CPS sensor?
Car starts fine and drives normal no problems at all and no fault/engine codes have appeared. After driving for a bit, at random the car will violently shake when coming to a stop usually at red lights. The whole car is shaking like crazy. If I press the gas a little more, it seems to help it go away completely until the next random occurrence. The thing is, it is so random like some drives it won't occur at all and sometimes it is every single stop. There was only one instance when the engine completely shut off. Had to turn the car off and start the engine again.
The thing is, I did fix a problem two weeks before I started noticing it shake, which was the CPS sensor. When this problem was present, the car never shook or vibrated though at all. Not even once. It only had a problem of either the car coming to a complete stall at red lights, or the engine would not start and I would have to wait 20 - 30 minutes to try again. The check engine code for CPS sensor did show up and so I replaced it and it worked with the car not having any problems for around 2 weeks and no check engine lights for the CPS sensor have showed up every since installing a new one.
Tl; dr - Car would stop at red lights and sometimes not start. CPS sensor fault code appeared and was changed with a new one. Then, two weeks later experiencing another problem with car shaking and losing power.
Spark plugs were changed at 100k miles last year. Car is around 116k miles right now. Could that be it? Or could it be a faulty/cheap CPS sensor? The CPS sensor is not Bosch, but aftermarket non-branded.
Any other possible reason? Thank you for reading and for any help!
https://www.europeantransmissions.co...n%20ME-SFI.pdf
Maybe I'm not getting the load part, so 50% would mean what?
