High mileage Clk550
You need to check that the engine is beyond the range for potential timing chain idler sprocket failure. Get the VIN and then use this site to find the engine serial number:
https://www.datamb.com/
It will be in the format of "272xxx 3x xxxxxx". Make sure it is beyond "30 088611" for the V8, or, if you consider a V6 CLK350, then "30 468993". If not, then there is the potential for a very expensive failure. Search the forums for "balance shaft" and read all about it. Note that high mileage is also no guarantee that it won't fail. Some failed at 25K, others at 125K, or even at 200K.
Another thing to consider is that the transmissions up to MY2008/2009 tend to need more attention. Almost all will experience bad speed sensors that require a $1500 visit to the dealer. Also, the fluid needs to be changed every 40K miles and it's not a DIY unless you can safely lift the car to work underneath and while keeping the transmission pan level.
Furthermore, since you are a college student, i assume you do not have the ability to DIY (garage, tools, etc.), and also you might be on a tight budget and not have thousands of extra dollars banked to pay for repairs. While owning a MBZ can be very satisfying, and buying a used one can save tens of thousands of dollars, keeping them properly maintained and addressing any "problems" can become expensive. There is an old saying that goes, "There's nothing more expensive to own than a cheap Mercedes-Benz."
, I noticed that I hit 162,000. My all black interior, turned aluminium and black Napa, still looks brand new even at that mileage.Check the issues, be aware of them. If you can do the work yourself, it can be quite affordable tbh. -In my experience of two CLKs and 60,000miles.
Could you tell us more about the speed sensors issue? Is it something bad for the engine, or bad as in 'you'll get a ticket' because of high speed?
I suppose some features are triggered by speed, such as steering assistance, break assist maybe? I'm no specialist far from that, but any info on what do these sensors do would be great. I never heard of this being a common issue before, is that a common thuth for clk's ?
Thanks.
If I understood you well it would then not go over 2nd or 3rd gear? Or did you mean it would stay locked on 2nd or on 3rd and drive only at that? I can imagine being able to go to the shop on a 3rd, barely... but in second?!...argffffff... I would get beaten up in L.A.!
As for that link, there are some companies that do this repair. What they do is take your ECU out of your faulty conductor plate and transplant it into a new one. I have heard of one forum member doing this with success, but I have also heard of another who had an earlier model 722.9 and those require a new valve body as the revised conductor plate will not work with the older style valve bodies.
I have a question that I hope isn't too stupid. On my clk550 automatic transmission, as on a lot of automatics, one can change the max gear by shifting the stick. Is that bad to use manual shifting of max gear to mimic a manual transmission drive style? Using this feature can help push the rev instead of letting the shifting automatically engage to higher or lower.
Using it like a manual transmission, also gives engine breaking help.
Is it bad to do that for the transmission or the engine itself?
I hope my question won't make anybody shake their heads. I don't know much in mechanic but I'm leaning..
Thank you so much.
I can't imagine that shifting so aggressively is particularly good for the box, however generally since its a fluid coupling between gearbox and engine output, I believe the change will be somewhat dampened.
I quite regularly use my tiptronic, mostly for upshifting early, or for hill descent/overtaking.
Note that the gear number shown on the instrument cluster MFD is not the current gear, but the "maximum gear requested". What this means is that the MFD can show "3" but you might be in any gear up to 3rd. If you hit redline in 3rd, it will upshift to 4th and the MFD will then show 4th. You might also find that when you need a quick burst of speed with a kick-down, if you slam the throttle and at the same time double-tap the TouchShift to the left, you will quickly get the lowest possible gear, which may not happen just using the throttle alone.
I've been working on an exhaust product for over 3 years and do the testing in the drone ranges, so I drive at 1975 RPM and 2500 RPM most of the time. And I was manually shifting the gears since about 5K miles but probably didn't rev it as high as I routinely do now.
I bought the car new in Oct 2007. It has near 168K miles. The wear on the engine is probably about what it would have gotten to at 250K with "normal" driving. In regular driving, in "C" mode, the tranny always shifts in the 1500 to 1600 RPM range.
There were some boxes unchecked from my teenage years; I am trying to take care of those now.....
