1st prob with wifeys clk
Old Oct 3, 2018 | 07:25 AM
porkyluck's Avatar
2005 clk 500 cabrio w/ 120k
gear shifter will not go past neutral from drive....cannot shift into reverse-park. theres some type of lock engaged in the shifter, but if she takes her foot off the brake pedal the lock is removed and it shifts as normal. also releases if the engine is cut off. there are no other symptoms, lights, etc.
so is this a brake switch problem, shifter problem, or something else possibly? a local m-b garage said it is the shifter can be replaced $1200ish. if it is the shifter is the unit plug and play, no programming necessary? if so i can get a used one from a salvage yard for $150ish.
thx for any help, suggestions
Old Oct 3, 2018 | 03:53 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Probably the shifter has failed. You can replace it with any W203 or W209 shifter, no coding needed.
