How much more life left on my car?
I’ve enjoyed it for the 5 years I’ve owned it. I have kept up on the maintenance but it does need a few things done. The rear main seal has a slight leak, there seems to be a slight fluctuation in the rpm, and a settle vibration. Also at high speeds on the freeway it makes a whirling noise from the engine. A friend of mine said the engine sounds “tired”. I keep up on oil changes. I’ve enjoyed not having any car payments which is great. It still looks amazing for the age. How much life can I still get out of this car? It’s got some sentimental value which is why it would be hard to sell it. I know it isn’t worth a whole lot of money but let’s say I keep putting money into it. Will it last for a long time?? Will it eventually crap out at a certain mileage?
Your rear main seal leak would be my only concern with your car. I don't have any idea what the cost to repair that would be.
They either run well or run poorly or do not run at all.
All depends on how much you are willing to spend to keep it on the road versus book value.
In theory you keep it on the road forever as long as parts available.
So if worth $1000 I would not spend $20,000 to keep it on the road unless you think in 10 years time the value will increase.
You have to decide...
But I would say you should easily be able to get 200K out of her with normal maintenance.
You can ignore rear main seal if you keep up with checking oil level and can live with stain in driveway.
If MB does normal service they tend to find things wrong and let you know as that is how they make the big bucks..
