Rotor bolt stuck, can’t remove
I have another thread as well, but want some advice. Putting on new rotors and pads on the front of my CLK350.
So had time this weekend to start. Passenger side brakes including rotor... no real issues. Driver side... different story. Alignment set screw in the rotor is already stripped when I get to it. So... try the T30... nothing to grab. Off to the parts store for and extractor. Drill the center hole, insert extractor and begin to turn and it immediately snaps. So now I am in a mess.
Work for 3 hours trying to drill it out, can’t get the center drilled because of the extractor.
Now i I am trying to figure out what to do... can’t break the rotor off because of the set screw... have no torch to melt it loose or heat it out. No way to weld a bolt on to spin it out... will have to find some bits to be able to drill it out. Haven’t even thought about the shock/strut yet.
If if I can’t get it out, will have to find a garage who can and tow it there... any thoughts?
All I can say so far is, never buy the Chrome Vanadium steel extractor sets... they are apparently not as strong as the bolt itself. Have to try to buy a bit today to drill it and the bolt out. Still can't get the rotor off with plenty of the bolt ground out (most of the head of it is gone) and some serious pounding. If I can at least get the rotor off, I'm somewhere.
So I managed to get the rotor off. With the help of Cobalt drill bits, a chisel and a lot of patience, I was able to drill through the rotor around the bolt and stuck extractor. The extractor was eventually worn out of the remaining parts of the bolt (minimal, though they still stick up out of the hub). I was able to finally replace the rotor and finish the brake replacement, though it is a bit trickier now to insert the lug bolts as you have to keep the rotor aligned before putting the wheel back on. But it is all together..and rolling again. Strut is next on the list for replacement... of course it has to be the same wheel that I had this problem with that needs replaced...
MBworld Guru
I'm glad you got it taken care. Just for future reference, you might want to invest in one of these:
https://www.lowes.com/pd/CRAFTSMAN-3...Set/1000594839
And of course a good quality set of Torx bits.
MBworld Guru
Another trick there is to use the impact tool along with a flathead bit that barely does not fits in the rounded-out Torx hole. As you hammer on it, it will dig itself in and get a bite.
I know this retroactive advice doesn't help you, but maybe the next guy that comes along and searches the forum.
I completely understand that in my previous home. BUT... two condos later and now a very small single family home with minimal storage in the garage and NO basement... I live in SW Florida, I have little room for excess tools. If I can't use it often, don't want to buy it. Also, no room for a compressor (or I would have to ditch my golf clubs)... so manual it is for me for now... until I decide I am done with everyone else and just put a lift in and buy a classic car to spend all of my time working on, then the whole garage will be full of stuff.
