Aftermarket radio cause no start?
2006 CLK500
I suspect the radio is not the issue if it worked for a year.
You need to start with the basics - fuel delivery, spark, etc. A common cause of crank but no start is a bad CPS (crankshaft position senor). If it's not cranking, then check voltage at rest and when trying to crank, and check the starter solenoid fuse and relay.
In this case, i suspect either (a) a voltage issue or (b) some wires unrelated to the radio, but related to the ignition switch, were disturbed during the aftermarket install.
