Rear window rolls down a bit, then jams
I just got my car back from the dealership for an oil leak repair (cam cover gaskets), and now I noticed that my rear left window will no longer roll down all the way. It goes down an inch or two, then gets stuck. I tried to push it down, but it feels like it's physically jammed on something. I can hear the motor trying when I press the button, so I know it's getting power. Has anyone had a similar problem? I've read that the regulator assembly is a $500+ part, but does the whole thing need to be replaced if the motor is still good?
It's very common problem https://mbworld.org/forums/clk-class...ndow-pics.html
You can buy entire assembly or only repair kit (as i did https://mbworld.org/forums/clk-class...ml#post6937605)
It's time-consuming job it's not going to be cheap to get it fixed by dealer.
Link to diy tutorial https://www.youtube.com/watch?v=gRhB...ature=youtu.be
I'm parting out the 2006 W209 CLK350 and have rear left regulator available and working if you'll end up needing to purchase this part.
Thanks for the video, but that is a crap ton of complicated work. Is the coupe any easier? If not, I think you just motivated me to just leave my rear windows up lol.
I just dismantled the coupe - definitely not easier. Actually it took me more time than convertible since I didn’t know the spots for a couple screws. Side panels removed in different way - need to release the lock. There is a videos on YouTube about Coupes.
nkx1 (12-08-2019)
I did this job for the first time about a month ago. It is a little tedious but not hard. Id say it was about 2 hrs all in and that is because rewinding the cable took me some time to figure out. Coup btw.
