2005 clk 500 Mercedes Benz won’t crank over
I put the wrong battery in not an AGM battery and it quit on me I got it home and am jump starting it and it turns over but doesn’t crank and it did before what could be wrong?
![](https://mbworld.org/forums/images/ranks/veteran_navy.png)
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
some Mercedes benz require you to have constant battery flow while changing batteries. If you do not it does something to the computer and you have to reboot it. I do not know what exactly they do but I know my 2014 did not require the constant power supply. Someone here might know what you have to reboot. You do not have to get a agm battery that is not the problem.
JCalcott (12-29-2019)
Received 3,955 Likes
2017 GLE350 4MATIC
Welcome! Please post a photo of the CLK.
chassis (12-29-2019)
2017 GLE350 4MATIC
Nice CLK!
Have you scanned the car for codes ? Easiest way to start would be to get it scanned for codes, then see what codes are present and go from there.
As I understand then your engine turns over but does not turn on ? Or the engine doesnt even turn over when you turn key ?
MBworld Guru
If it cranks but does not fire (start running) then it't not a battery issue. It's most likely a fuel delivery problem. It could be a bad fuel pump, pump relay, or even a bad CPS (no signal from the CPS and the ECU will deactivate the fuel pump).
