04 CLK500 no Start, key turns all lights come on and can shift out of park
Any Ideas for this no start, I currently has the battery disconnect switch off to let it sit overnight and see if anything changes after a couple ours left to reset everything
These are the codes my scan tool was able to pull(Autel AL619) though I have since cleared the and still no start..
P0600 $10 Serial Communication link
C1022 CAN communication with engine system faulty
C1024 CAN communication with engine system faulty
C1029 Fault in CAN communication with unit n73 (EIS [EZS] Control unit)
c1035 MIL ON&Stored& Current The signal from compnent N49 (Steering Angle Sensor) is Faulty
C1038 Engine Control Module not identified or incorrect control module
I'm currently contemplating getting the iCarsoft MBII or possibly the more expensive multi-car unit (if it too will give me access to all the MB modules) or possibly the clone STAR diagnostic stuff if its available
I agree those are a lot of communication/potential electrical errors. Unless the prior owner was just a complete bone head however, they are probably from a single source. The last error regarding the ECU would be where I would start. Perhaps one of the gurus here can tell you if that is an err common to installing an ECU not linked to the car. The SAM would be my step 2 to investigate.
There is a starter relay but it would not generate all those comm errors. (I assume the ignition switch was in position 2 when you got the errors)
If a diagnostic tool can read the ECU (your ECU is using k-line, not CAN bus for diagnostic) then it's probably just faulty wires.
Resistance should be around 60 Ohm, but be sure that the car is completely off, since you removed your ECU I'd image that you already disconnected your batter
. Otherwise not "sleeping" modules could mess-up reading.
