Instrument cluster not working
Old Jan 22, 2022 | 05:14 PM
Jashal56's Avatar
W209 or (C209) 2003 CLK240
W209 or (C209) 2004 CLK240
Left the car to sit for a 2 weeks. Came back and car starts and runs well but instument cluster is totally dead.
Have changed fuse 42, but a red blob light comes on for 1 second and the instrument cluster still did not work.
I have removed the instrument cluster, but how do I power it on without it connected to the car?
this will allow me to rule it out it as faulty.
Thank you
Old Jan 23, 2022 | 09:53 AM
Jashal56's Avatar
Bump
Old Jan 23, 2022 | 10:47 AM
Jeko Atanasov's Avatar
CLK 500,m273
PIN 4 and 6(+12V)
PIN 1(Ground)
PIN 17 and 18(CAN L and CAN H)
Old Jan 23, 2022 | 11:55 AM
Jashal56's Avatar
Originally Posted by Jeko Atanasov
PIN 4 and 6(+12V)
PIN 1(Ground)
Thank you, what is CAN L and CAN H?
I think I'm, just going to take it to a garage to check?
Old Jan 24, 2022 | 02:49 AM
CLK 500,m273
Just plug only voltage- three wires
Old Jan 24, 2022 | 10:03 AM
Jashal56's Avatar
Clk instrument cluster (red blob of light)
Please help, the instument cluster is totally not working I changed the fuse and it just shows a blob of red light for 1 second. Or when I touch the plug connecting to the unit, sometimes it shows the red blob of light for 1 second again.
What's wrong with it. It was working perfectly before I left the car to sit for about 1 week, in wintery weather, then it stopped working?
I have taken the unit off and opened it to see if there is any damage and it does not look like it. I can't test the speedo out of the car as it is too much for me to cope with.
What is wrong how can I fix this?
Old Jan 24, 2022 | 01:14 PM
CLK 500,m273
Change the cluster
Old Jan 24, 2022 | 01:53 PM
Jashal56's Avatar
Change the cluster
Would it be a straight swap? Would a replacement work?
What would happen to my mileage?
Old Jan 25, 2022 | 09:12 AM
Jashal56's Avatar
Please?
Old Jan 25, 2022 | 11:01 PM
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2012 E550 coupe (sold), 2017 C63 sedan (sold), 2018 C63S Coupe
Have you tried leaving it unplugged for a while (like overnight) and plugging it back in? Kind of a hail mary, but it has worked for some in the past. If you need a new cluster, ideally get one with the same part number as your original. You'll need to take it to a specialist who can "clone" your original cluster over to the new one. It can be done do both a new or used unit. This will keep the mileage correct.
Old Jan 26, 2022 | 04:51 AM
Jashal56's Avatar
Yes, I've left it unplugged for about 30hours, still not working.
Okay , would try a replacement thanks.
Old Jan 27, 2022 | 12:19 AM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
Unfortunately simple replacing won't work.
Even if you find a cluster with the same part number mileage won't be displayed (you'll see dashed instead). I'm sorry I don't have time to explain everything right now, but I'll share more details tomorrow.
Old Jan 27, 2022 | 12:23 PM
dzmitry's Avatar
Alright, so here some information I promised :
Unfortunately those instrument clusters go bad which is not uncommon.
What to do with the cluster depends on you skills: I'd imagine that repairing it in a repair shop (there are plenty of them on eBay at least) would cost you about $300 (based of fact that it's clk240 I'd assume that you are not in the US so it might be different in your location).
If you know how to solder (our you have a friend who knows how to solder) you can buy a used unit (ideally with the same part #) and swap eeproms (it contains cluster configuration, VIN and mileage) between clusters (relatively easy job).
If you know a little be about electronics I can explain you how to transfer eeprom's data between clusters buy simply using Raspberry pi
If you have access to professional diagnostic tools like MB Star, Autel MaxiCom/MaxySys, AVDI, etc then it's easy to "re-learn" a used cluster to your car (virginazing first)
And the last option is if you don't care about seeing current mileage you can just install used cluster (again ideally with the same part # since it should guarantee the same cluster configuration)
Old Jan 28, 2022 | 09:56 AM
Jashal56's Avatar
Hi, I have replaced the instrument cluster and it is now working
However, I'm getting the SRS light come up on the dash ( "Restraint System Defective Visit Workshop").
The mileage is also different to mine and is showing "-----------" instead of the true mileage.
Please how can I clear the SRS?
Old Jan 28, 2022 | 02:02 PM
Jashal56's Avatar
Yes I have a Raspberry Pi could you tell me how to exchange the EPROM data from the old cluster to the new cluster ? That's sounds awesome if possible.
Old Jan 29, 2022 | 06:52 PM
dzmitry's Avatar
You are going to need SOIC8 Clip
like this one like this one
(cheaper one should be fine as well) to connect to cluster's eeprom (it's 24C16 or similar, here is a https://www.mouser.com/datasheet/2/268/doc0180-1180742.pdf) check SOIC8 pinout: you need to connect GND, VCC, SDA, SCL to appropriate pins on RPi (i2c protocol), just in case you can connect WP (write protect, although I think they have internal pull-down resistor, so it should not be necessary, but not 100% sure) pin to GND.
And yeah you gonna need to disconnect main board completely otherwise I had issues with connected to the eeprom in circuit (i think there is a workaround, but disconnecting is just simpler).
Now I need to find a script I wrote for reading/writing that eeprom
Old Feb 2, 2022 | 12:11 AM
Jashal56's Avatar
You are going to need SOIC8 Clip like this one (cheaper one should be fine as well) to connect to cluster's eeprom (it's 24C16 or similar, here is a datasheet) check SOIC8 pinout: you need to connect GND, VCC, SDA, SCL to appropriate pins on RPi (i2c protocol), just in case you can connect WP (write protect, although I think they have internal pull-down resistor, so it should not be necessary, but not 100% sure) pin to GND.
Ok so the script will be used on both clusters?
Old Feb 2, 2022 | 08:15 AM
CLK 500,m273
Replace eeproms,ot test with PCB plate without desoldering
Old Feb 4, 2022 | 01:29 PM
Jashal56's Avatar
I have swaped the old "Green board" in the picture with the new "Green board" and the instrument cluster did not work.
So from that test, I know that the old "Green board" has issues. I don't know exactly what is wrong with it.
Green board from old cluster, does not work when connected to new cluster.
Which chip is the EEPROMS
Old Feb 4, 2022 | 02:26 PM
CLK 500,m273
24C16 or 24C17
Old Feb 5, 2022 | 08:34 AM
Jashal56's Avatar
24C16 or 24C17
So all Has failed, could you post them link to the machine I need to switch the mileage over? Or recommendation UK shop that will do it for cheap?
Old Feb 7, 2022 | 07:36 AM
CLK 500,m273
+359887775344 Write me on viber on whatsapp
Old Feb 8, 2022 | 12:38 PM
dzmitry's Avatar
Hi there,
Sorry folks, my move took much more time than I anticipated (turned out with a little baby everything takes 10 times longer :-D ).
If Jeko Atanasov has experience with Mercedes clusters you'd better to listen to him , I'm just a hobbyist, although I had success with transferring data and virginizing couple of clusters.
Old Mar 12, 2022 | 01:05 PM
Jashal56's Avatar
I sent the instument cluster off for repair.
It has come back but all the warming lights are stuck on the main headlight is on as well as no noise from the indicators?
Old Mar 12, 2022 | 02:49 PM
Jashal56's Avatar
Anyone please?
Old repaired cluster
The old cluster's lights come on, but all the warning lights also show up. When the engine starts , an additional error message comes on " Display faulty Visit Workshop". Nothing works like it should, like the headlamp is always on, indicators make no noise, no fuel is shown in the gauge.
The mileage is correct though.
New used cluster
Still works properly like it should. However, it also shows SRS error and the incorrect mileage
