CLK 550 FUEL LEAK FIXED
Old May 27, 2022 | 10:00 PM
Scotslad2k's Avatar
2007 CLK 550 AMG
Lock ring and clamp underside
Lock ring and band clamp
Line going to fuel pumlp
Different type of spreader to remove lockring
Tool for removing band around lock/clamp ring
Tool to spread locking clamp for reinstalling,,usual use to remove piston rings
When I bought the car owner said no leaks,ha , fuel tank has been leaking gass for years through cracks in plastic on the fuel transfer pump behind driver's seat side. . I purchased from TRQ replacement unit $120 works fine everything matches up,bought the 105 degree angle adapter in order to get to the clamp bands no other choice. Clamp rings were still flexible enough to reuse. I cut the press on fuel line on the pump as depressing the clip lock would not release.Mercedes tech in town wanted $225 to do the swap ,figured I'd have a learning experience instead. Questions email me
Old May 28, 2022 | 11:03 AM
BenzBopper's Avatar
06' Audi Quattro, 00'SL500
You have some interesting tools. Cool though. I have always taken labor cost into account so I could justify buying the right tools for the job, then do it myself.
Old May 28, 2022 | 01:45 PM
dbldpr's Avatar
Veteran: Navy
Welcome looks like you did a great job
Old May 29, 2022 | 07:45 AM
Scotslad2k's Avatar
2007 CLK 550 AMG
Tools
The labor only by local Benz doctor was going to be $225 est. The speaker and angle drive tool was about $40 so a good add to my tool box ,I will definitely running the gas as low as possible before doing this job is a really good idea. [QUOTE=BenzBopper;8571251]
Old May 29, 2022 | 10:32 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W209 forum...
Old Jun 19, 2022 | 12:00 PM
Paulers's Avatar
CLK550
Think I am going to tackle this soon. I have a long crank issue on my car that has been sitting a while.
Old Jun 30, 2022 | 11:00 AM
Paulers's Avatar
CLK550
fixed my long crank problem
I replaced both pumps and installed the larger tank o-rings. Long crank problem solved.
$381 worth of parts Parts (including tax and shipping):
$16 - Angle tool for clamp
Amazon Amazon
$140 - TRO drivers side pump FPA61547 https://www.carid.com
$25 - URO fuel tank pump seals 2114710579
$200 - Genuine Mercedes Fuel Pump Module Assembly P/N: MB-2094700594 autohausaz.com
