W209 AUX Port Sound: 2008 CLK 350
Old Jul 31, 2022 | 10:50 AM
ktim1249's Avatar
2008 CLK 350
I have a 2008 W209 CLK 350. It had an iPod connector coming through the wall of the glove box. I wanted to use the AUX 3.5 mm cable instead. I purchased one and had it delivered. However, when I opened the panel to the side of the dash where the glove box is I found there was one already there and it was plugged into the correct connector in the wiring running along the floor by the door. I took out the iPod connector but had to cut the cord on it to get the wider plug part through the hole. Probably at this point that was not the best thing to have done. I pushed the AUX 3.5mm port through the hole in the glove box and everything was good. However, when plugged my iPod into the port with the 3.5mm cable on it I get no sound. The cable works this way just fine on another car I have. I read somewhere that when the iPod jack is installed it disables the 3.5mm AUX port. Can anyone help me figure out how to reactivate the 3.5mm AUX jack? Thank you
Old Jul 31, 2022 | 05:06 PM
KJ04PSZ's Avatar
CLK320
Probably a daft question.....but the head unit is on the right input? AUX?
Old Jul 31, 2022 | 05:08 PM
ktim1249's Avatar
2008 CLK 350
Yes. Not a daft question at all..... I checked it three or four time....
Thanks though...
Old Jul 31, 2022 | 05:12 PM
ktim1249's Avatar
2008 CLK 350
I checked that three or four times. I was doubting everything I was doing.
Old Jul 31, 2022 | 07:29 PM
zill's Avatar
2008 CLK 550 2012 C300
KT,
if you can return to the oe setup try this. I have the same model as you.
tune2air.com.
iPod Bluetooth interface.
zill.
Old Aug 1, 2022 | 07:22 AM
ktim1249's Avatar
2008 CLK 350
Originally Posted by zill
KT,
tune2air.com.
zill.
I read up on this and some of the problems people had with it. I think I just go ahead and pay for satelite radio. I have it on my other car and like it.
Old Aug 4, 2022 | 10:59 AM
Stewball350's Avatar
A209 350
Aux iPod connector
Hi I have the same car.I have the old 30 pin iPod connector also in the glove box.how do I update it either to plug my iPhone in or connect my phone via blue tooth.
playing cds and listening to radio is painful.
Old Oct 23, 2022 | 08:42 AM
wagzbenz's Avatar
CLK 350A Cabriolet
Hi, did you find anything yet? If not try this https://www.ebay.com/itm/11557636688...Bk9SR6jHs82AYQ . I have one of these Buvee's and it's great. If you don't want to pay that much just Search on Ebay for 30 pin bluetooth.
Old Oct 23, 2022 | 05:04 PM
daking1959's Avatar
2009 CLK 350
listening to the radio, or cd,s is painful?
Do you have the Bose, or HK?
I believe most cabriolets have the HK system. I have no sound problems with the HK system in my car, I'm not a autophile, but this system sounds pretty good to me.
My only grip, is the 6 disc changer in the glove box has stopped working. I've tried a couple that I purchased from ebay, but none of them have worked.Cd changer in the head unit works great, but I do miss having the 6 disc changer.
Old Oct 23, 2022 | 07:13 PM
wagzbenz's Avatar
CLK 350A Cabriolet
Hi, I used to own a Car Audio store when I lived in the St. Louis area. Then I worked for this company that was a Car Stereo Distributor for 12 years. This is my first MB found a cherry CLK 350 Cab, it's a 08 but with very low miles. It has the HK system in it and it does sound excellent. I also had problems with my CD changer, and I have been able to repair audio equipment, but the changer has many problems, so I removed it and got the Buvee bluetooth unit and stream just about everything from my phone. It doesn't have any loss of quality in the music. If you remove the CD changer you do have to get a Fiber loop for the antenna so your system will work. Just letting you know what you up against.
Old Oct 23, 2022 | 07:34 PM
wagzbenz's Avatar
CLK 350A Cabriolet
I used to own Car Audio Store in the St. Louis area in the 90s. I do have a HK system in my CLK 350A and it's a Great sounding System. My CD Changer also quit working, and I do know how to repair equipment. It did have many problems, mostly the cable back to the head unit, so I removed it and just use this Buvee Bluetooth unit thru the interface cable, and I can't hear any loss of quality in the music. Mostly listen to all my music I put on my phone or I stream Sirius XM off my phone. Just telling you that if you remove your CD Changer you have to get a Fiber Loop and install it into the antenna system or you will not get any audio off anything.
Old Oct 24, 2022 | 09:11 AM
daking1959's Avatar
2009 CLK 350
Many thanks for the reply.
I do have the Ipod connector in the glove box. Will the Bovee work with the ipod connector?
Amazon has the Bovee $89.
Old Oct 24, 2022 | 09:36 AM
wagzbenz's Avatar
CLK 350A Cabriolet
Yes it will, don't get the one that has a cable on it, that one fits the Mercedes that has the connector by the gear shifter. The ebay link I put on my last message is the same I have (shown in the pic below) is for $75.00. There are others off brands that will work, but I choose the Bovee cause I've heard of them before and I know the name. The others will work too, and they are cheaper, but I don't know how long they will last. I have had mine for over a year. Now this will not make it able to answer your phone or make calls. That's something else, and the phone system will not make it where you can stream music off your phone.
Old Oct 24, 2022 | 09:42 AM
wagzbenz's Avatar
CLK 350A Cabriolet
If you do need the system for the phone, go onto ebay and search for Cellguy, he is where I got mine and he talked me through the installation. He's a good and Honest man, you can see his name all through these pages, I also think someone even has his phone in here.
Old Oct 24, 2022 | 09:55 AM
daking1959's Avatar
2009 CLK 350
Many thanks
Old Oct 24, 2022 | 10:06 AM
wagzbenz's Avatar
CLK 350A Cabriolet
Glad to help, I have gotten so much info off the site, glad to give some payback.
Old Jun 21, 2024 | 03:41 PM
derekwh's Avatar
2012 E350 Bluetec, 2014 GLK250, 2007 CLK350 convertible
I have a 2007 CLK350 with the ipod connection in the glove box, if i use the Bovee unit to stream music will the bluetooth interfere with the bluetooth from the existing phone connection?
