Ticking after oil change
Started her up, and there is a slight ticking briefly, then it went away. Started the car this morning and still a light ticking. I drove the car around the neighborhood got back home and no ticking. Car ran smooth as glass.
Any Ideas? Happy New Year to All
I have heard it's the lifters and goes away after the engine is warm. Mine does it as well on a cold start but quickly dissipates. Others might have a different idea.
I think the ticking is during the brief moment the oil filter housing fills, after that the oil pressure builds. That was the situation with ‘85 380SE, anyway. Don’t hear it much on the CLK 550.
zill.
A solution that has worked well for me (on cars with a dipstick) is to drain a small amount of oil (1Qt is best) and top up with a thinner viscosity oil, like ATF. I use ATF partially because it things all of the oil to help it flush through hydraulic lifters and partially because of the extra detergents it uses. If you've ever replaced the filter in your Mercedes transmission, you'll see how CLEAN it is in there!
I drained the oil it was very clean. I put about 2k miles on the car last year.
