2007 CLK350 Suspension Upgrade
I have an 07 CLK350 that vibrates/shudders at around 60mph and when braking. Fairly certain it's the control arms and I just ordered a new kit, however I want to change the front (and possibly rear) shocks/suspension because whenever I hit a bump it's very jarring and hard. Can someone point me in the right direction to what parts I can order? I'm a novice and still learning, and don't know what needs replacing, such as the coils/spring, and the struts. Thanks in advance!
But you are correct; at this age and especially if you are noticing the shaking under braking, you should probably be replacing:
Front control arms
Upper strut bushing
Upper strut bearing
Struts
sway bar end links
The entire kit for front suspension was around $1,000 from FCP Euro. If you wanted to upgrade to factory Sport suspension, all you'd need to do is buy the Sport suspension kit and then source the Sport front sway bar and brackets.
Front control arms
Upper strut bushing
Upper strut bearing
Struts
sway bar end links
