Cluster Fault or SAM?
Old Jan 2, 2024 | 10:49 AM
Neil Hansen's Avatar
clk 500 2002
these faults keep repeating on a cycle , I’ve taken a video but can not upload as it’s more than 20mb
car was sitting on the drive for 2 months . Started up with no faults when I returned from my holiday .
following day I noticed the boot liner for spare was discoloured and boot smelt of damp , the liner was wet and mouldy. Removed it to dry and started Car and noticed the cluster had SRS warning light , rest of cluster was dead , just the cruise control indicator was on between 20 and 60 mph. But as the days have gone by the cluster has got progressively worse with faults .
the picture attached is most recent.
should also mention there was some water moisture on the SAM in the boot .
so could be possible SAM faulty ?
Any help would be appreciated thanks
Old Jan 8, 2024 | 05:02 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You need to scan your car to understand what active faults are messed up.
Rear-SAM likely needs replacement due to soaking
