How to take off engine cover?
Old Sep 22, 2005 | 04:32 PM
M1M2M3's Avatar
Mercedes
I have an 01 CLK55 I just ordered the Green Filters. I havn't recieved the filters yet but they're on the way! How do I remove the engine cover? Thanks for your help.
Old Sep 22, 2005 | 07:55 PM
skytop's Avatar
You could do a search to find this frequently asked question to get a complete DIY.
On the W209 model and probably the same on the earlier 208 model, remove all dirt/debris and just carefully lift the cover vertically. It is held on by a number of plastic pegs that sit in rubber sockets. Have a clean rag at the ready to cover the engine air intake which is at the rear center of the engine.
You will also need a torx screwdriver to remove the two filters from the housing. Be sure to blow and wash the entire assembly off before replacing.
Old Sep 23, 2005 | 11:43 AM
M1M2M3's Avatar
Mercedes
Old Aug 20, 2008 | 03:20 PM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
I saw a thread with pictures and DIY of how to remove the engine cover
to change the air filters...
Can't find it anymore!! anybody can post me the link for it plz
Old Aug 20, 2008 | 05:47 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
just put your hands on either side of the airbox and PULL UPWARDS! It clips onto these rubber mounts so you have to tug a little. Disconnect the hoses (they just slide on, friction fit). Then you just go inside to the AC and remove some torx screws on the underside to change the filters.
Old Aug 20, 2008 | 08:20 PM
MARTYMAR's Avatar
07' IS 350, 08' E550
Removing Air Filters step by step...
Thank me later!
http://euroteckmotorsports.com/index...5928&pageid=84
Old Aug 21, 2008 | 08:58 AM
FatTony001's Avatar
WOW thx Martymar!!! that's the thread I was looking for!
Sweet
Old Aug 21, 2008 | 09:38 AM
MARTYMAR's Avatar
Sweet
No Problem!
