Any info on Supersprint exhaust for 209 CLK55?
Best regards,
Matt
Best regards,
Matt
even Brabus doesn't touch the AMG exhaust system
I'm in agreement in that the stock AMG exhaust can't be improved much from the catalytic converters on back. Personally, I believe that there are gains to be found by replacing the stock exhaust manifold with a set of headers, but no one makes a reasonably priced header for the CLK55...
Best regards,
Matt
p.s.) You're probably right in that I should call, but I would also like to see some pics...
If the Supersprint muffler/exhaust isn't all stainless, that will seal the deal right there! I don't care for the baked black/,mild steel finish at all. I've noticed that some of SS systems are all stainless, and I was waiting to see, but if their center pipe will work with the Eisenmann muffler, that just may be the best of both worlds, so to speak. Anyway, thanks for the input!
Best regards,
Matt
they aint got **** on ss when it comes to exhaust... unless they out-source it from a specialty co. which i dont think they do
what do u guys think of straight piping? i dont care about how loud it would be
im thinking of putting a slr type exhaust on my car.... no mufflers though
I already went through this and you will be limited on whats avalible . You have two good choices out here. #1 Is Kleemann & #2 is Carlsson
I chose the Carlsson , Sport rear silencer with 2 tips . part number 18-33-0170-E ,for a CLK 55 AMG List price $1475.00. It was stainless Steel . It fit & Finish was very good . You will have to cut the exhaust pipe off the OEM AMG muffler , but you may have too shorten their measurement by 1/2" , . The opening at the inlet on the Carlsson muffler is 3 1/4". Stock AMG S.S exhaust pipe is 3" . When the pipe is expanded to fit the muffler it will shorten a little . Do IT Slowly as so you don't crack the pipe . This gives a nice clean path for the exhaust to flow. Helps rid of unwanted Hisses, Whisles .
I did the install in my garage by myself , took the pipe to the Midus Muffler Shop , Flipped the installer a $20.00 ( TRY THEM LATE IN THE AFTERNOON they are usually slow) The exhaust tips would fit into the OEM rear bumper cover , but off center about 3/4 " . you can order a Rear skirt for a perfect finish. Carlsson can be had through Neil@ euroteck.com / Carlsson N/A 305-717-3133 www.carlssonAmerica.com
Oh yeah , The sound !! around town it turns it up alittle Just so you know it is there . Nice GT sound but not obnoxious. . At hwy speeds light throttle , Cruise control on ,anywhere between 55 to 75 mph. It is dead Quiet . or at lease Equal to the AMG muffler. ,BUT HAMMER down it with speak with authority . My K & N sound pessure meter increased from 77.6 DBs (stock AMG) too 79.5 DBs with the Carlsson Muffler . At Idle in gear ,windows up no air running AMG was 46 DBs , Carllson was 47.3 DBs.
Good luck , hope this helps ___PTE___
