AMG Air Filters vs. K&N Air Filters...
Old Nov 21, 2005 | 03:31 PM
Learso's Avatar
2009 GL450, 2009 G55 Mocha Black with Cognac Interior, 08 911 Turbo Cab, 08 CLK63 Black Series
Just consulted MB regarding this question as I am coming out of warranty and thought maybe I could "upgrade" in the air filter department too...but I guess I am glad I asked first. It would appear that K&N does have some issues with our cars. Read the email I got from MB:
"Stick with the AMG filters. The K&N filters are cleaned with an oil-based solution. We have found the residual oil that is left on the filters gets into the mass air flow sensor (regulates air/fuel mixture going into engine) and destroys it. The mass air flow sensor goes for about $600.00....not worth risking it."
Old Nov 21, 2005 | 03:39 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Don't be afraid of the K&N'S.I've run them in every vehicle I've owned - my 97' Maxima has 173k on the clock - 140k with the K&N's.As long as you follow the directions when "oiling" I repeat "oiling" you're o.k.Just remember you "oil it" not MARINATE IT.If they were a problem or defective I wouldn't put them in my C43.
Old Nov 21, 2005 | 05:12 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
NEver listen to the stealership.... they also tell us that we cannot retrofit commands and bi xenon head lights.....
Old Nov 22, 2005 | 03:14 AM
AMG_55's Avatar
mymbonline
i used k&n in:
94 e500
99 m3
00 528
03 clk55
no problems........ i do replace them though instead of cleaning/oiling
Old Nov 22, 2005 | 10:57 AM
newton22's Avatar
BMW E39
Might also consider green filters. They're just like K&Ns, except are less oily out of the box. If you with K&Ns, just make sure they're oiled correctly as already stated.
Old Nov 22, 2005 | 11:35 AM
~CL500~'s Avatar
E90 N54 & W251
Originally Posted by AMG_55
i used k&n in:
94 e500
99 m3
00 528
03 clk55
Since you replace them instead of oiling them, how long do they last between replacement intervals?
Old Nov 22, 2005 | 02:36 PM
billybenz's Avatar
2006 CLS 55 AMG
use them c-43 said it best oil them not marinate if you just put on a little oil part of the paper will still be white then wait the capillary action will draw it through the whole filter
Old Nov 22, 2005 | 08:59 PM
Learso's Avatar
Although I agree that proper oiling would avoid the problem, who would oil them? I too would rather replace then clean with oil. Just not worth leaving it to someone else to do. But the questions is really if anyone here can honestly say it has made a significant difference in their cars performance?
Thanks,
Learso
