Kleeman Headers!
Old Jan 8, 2006 | 07:54 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Kleeman Headers!
Can the Kleeman headers they make for the CLK55 work on the W203 C55?
And are they infact different than the headers they make for the E55 W210 and 211?
Anybody know?
If so then the CLK headers should bolt up to the C43 I hope.
I know the stck exhaust manifolds are different between the E55 and the CLK55 I believe.
Old Jan 8, 2006 | 08:19 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Kleemann headers
I'm Just install a set on my 03 CLK5.5AMG last night. It was tight!!! . I had to use a hammer and some wood to push the heat shields on the side & over the motor mounts . .About 4 hours of work , and had to loosen the motor mounts & jack the motor. Funny think I found the motor mount bolts were not what I would call tight??? I loosened them with a 1/4 ", 3 inch ratchet , with light wrist action . The top side mount bolts was the same . I used a little red locktite and 40 FT lbs .
If your 208 has a larger engine , I think they would fit. Here's some pictures of the OEM manifolds , next to the headers . I have already done a dyno , Mtr has new S/P s. Renntech air , box Green filters. And Kleemann ECU upgrade. The car is going to the muffler Shop to have the rest of the exhaust system built, Using 100 cell cats & Carlsson Muffler. Then back to the dyno
Old Jan 8, 2006 | 09:08 PM
Co 55 AMG's Avatar
W208
[QUOTE=PTE]I'm Just install a set on my 03 CLK5.5AMG last night.
Nice!
Old Jan 8, 2006 | 10:00 PM
ProjectC55's Avatar
Perfect.Those stck clk55 exh mani's look exactly like the stck exh mani's on the C43 which I am now using on my 5.5L motor that's in my C43. The E55 mani's are different. the kleeman headers for the CLK55 should wrk for the W203 C55 and the W202 C43's. Nice pics and thanx for your help. Kleeman Headers,here I might come!
As soon as you get your car back please post the dyno results thanx!!
Old Jan 8, 2006 | 11:18 PM
JamE55's Avatar
Out Of Control!
PTE,
Are those Kleemann headers you have there coated or just plain polished? Looks good. Have tested it out yet and if so did you notice a huge difference between the stocks?
Old Jan 9, 2006 | 01:21 AM
H-MAN's Avatar
'07 Carrera S, '31 A 5W hot rod, 4Runner. Sold CLK55
OK I'm jealous. I'd love to hear the difference the headers would make. Did you buy those at full price?
Old Jan 9, 2006 | 01:34 AM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
I'm very insterested to see your dyno results with those Kleemann beauty's. Do you still have cats and how is the sound. I'm thinking of doing this because I think it will work well with my supercharger and I would wrap them to help reduce motor heat.
Let us know
Mario
Old Jan 9, 2006 | 11:13 AM
Cory @ Kleemann's Avatar
Former Vendor of MBWorld
The headers pictured will not work on a W202/208.
Old Jan 9, 2006 | 03:48 PM
ProjectC55's Avatar
OK ,Well how do you know is my next question? Is the engine bay in the 209 bigger? I need to know that you know this for a fact and if you tried it. That exhaust manifold in the pic is the same as the C43 exh mani.
208 CLK55 mani(part#)=202 C43 exh mani Now does Kleean make a header for the 208 lk55?
Old Jan 9, 2006 | 04:06 PM
It does not matter if the manifold on the C43 is the same or not. What we are concerned with is making it around the steering box. W202/208 cars use recirculating ball steering, where a 203/209 uses rack and pinion which does not have a steering box to contend with. W202/208 headers are unique to that chassis because of the steering system- there is simply not enough room for a header like the one in the picture.
How do I know? Let's just say it's my job to know....
Old Jan 9, 2006 | 04:16 PM
ProjectC55's Avatar
Give me a call! I would appreciate it Cory.I'll PM you my tel #!
Old Jan 9, 2006 | 04:26 PM
c55m8o's Avatar
'98 C43/55 AMG Speedybenz Susp. & MBenzNL On Board -- '88 560SL -- '09 JCW MINI -- '97 Jeep TJ Sport
wow, flying under the radar huh Cory, w/o the co. you work for in your sig... :v
...so then you're saying we're SOL Cory? No way, No how? ...or are we misunderstanding and you are only saying "no headers like that, we do have some but they are different?".
Old Jan 9, 2006 | 04:28 PM
ProjectC55's Avatar
Thanx Cory.I'm glad I quit while I was ahead!!!!You stopped me right in my tracks!
Old Jan 9, 2006 | 04:29 PM
ProjectC55's Avatar
Steve he actually does have headers for the C43!
Old Jan 9, 2006 | 04:31 PM
c55m8o's Avatar
Ah, you answered my correction to my question above. (I gotta stop editing everything after 1st posting them!) Any volume discount pricing...?
Old Jan 9, 2006 | 05:25 PM
PTE's Avatar
PTE
CLK 5.5 headers
I had them coated by a local guy ,here in Stuart FLA.
I paid retail , but anything else I looked at was not as good as the Kleemann , for increase HP. IMHO
Chris @ C2Design & Cory at Kleemann USA are Great to work with
I will dyno the car after I finish the exhaust system. This will be the 20th run on the dyno.
Next will be Kleemann Cams , this may take a little longer. I want to get the valve covers polished and clear coated.
Old Jan 9, 2006 | 05:30 PM
c55m8o's Avatar
BTW, are you running N/A or F/I? I was under the impression their cams are geared for F/I engines, in that F/I wants [much] less overlap between intake and exhaust then you'd want for a "built" N/A engine. Please fill us in whether you discusses this with Kleemann. Much Thanx.
Old Jan 9, 2006 | 05:31 PM
dinko's Avatar
CLS55
What kind of gain do you expect from the cams?
I do agree to Chris and Spencer are top notch. Haven't had the chance to work with Cory as I'll leave all my work to C2 Design.
Dinko
Old Jan 9, 2006 | 07:11 PM
PTE's Avatar
PTE
Cams
The motor is a N/A , 3 valve 11 to 1 C/R. From what I understand , the motor will have a slight lope at Idle or as explained in the intallation guide ,a slightly lumpy idle - this is normal due the lift & duration of the Kleemann cams
My Guess is , that it will idle somewhat like a z06
DurationCRA intake 256 degrees
DurationCRA exhaust 268 degrees
peak timing 114 degree. I think that is center line
Valve timing CRA
intake opens 14 degree / closes 62 degree
exhaust opens 68 degrees / closes 20 degrees
Thats all I know , until I dyno the car when the cams are installed.. I do all my own work after I get off the road , and on the week end . Other than that , Talk to Brandon @ Kleemann USA
Old Jan 9, 2006 | 07:42 PM
JamE55's Avatar
Out Of Control!
Valve timing CRA
Are you running any aftermarket or modified exhaust system? If you're running stock exhaust the idle of the cams imo sounds sweet. It's not very noticeable but again i like it. It does sound a little rough but it's a sleeper. Best part is when i hit the mid rpm then it's on like a freight train!
Old Jan 9, 2006 | 08:05 PM
rflow306's Avatar
2005 E 55
Valve timing CRA
That's all I know , until I dyno the car when the cams are installed.. I do all my own work after I get off the road , and on the week end . Other than that , Talk to Brandon @ Kleemann USA
PTE please let me know when you go to the track again. BTW those headers look even better in person thanks for bringing them out on Friday. Please take some pictures of the cam install you are giving me bad ideas. :v . Regards Albert, see you soon.
Old Jan 9, 2006 | 08:38 PM
dinko's Avatar
CLS55
Keep me updated on the cams too! I plan on doing Headers soon and would like to get the most out of my N/A engine.
Old Jan 9, 2006 | 09:15 PM
c55m8o's Avatar
[figures snipped]
Woe, thanx for those details. That helps a good deal. The guy that did our [Carl and my] motor swap had been telling us we need cams ... Carl, ya up for it, w/headers?
Old Jan 10, 2006 | 01:30 AM
speedybenz's Avatar
AMG C43, 1999
PTE, Thanks for the cam specs. I think that if the lob centers where moved some so the intake side was advanced so it opened 5 degrees sooner and the exhaust cam closed 5 degrees sooner you would see some Hp.
Another company to coat the headers is Swain Tech. They spray a very thick ceramic coating on that really keeps the heat in. I can typically touch my headers after driving only minutes after shutdown. The only drawback is the coating is not shiny it is more grainy, like a fine silver sand texture.
Jeff
Old Jan 10, 2006 | 06:11 AM
ProjectC55's Avatar
Jeff
Yep swain tech is only a few hrs from here.Their coating wrks great as I've sent the turbine housing from my turbo charger to them for coating.After driving the hot side of the Turbo and exhaust manifold get cool enuff to touch for a few seconds.Without the coating you can't even put your hands near the parts. good call Jeff and their prices are pretty reasonable.
