Lowered Cars - Excessive tire wear?
Old Feb 16, 2006 | 10:09 AM
Chappy's Avatar
AMG
I've been asked recently about any tires issues and wear with my current setup. I thought a new thread about this would provide some public feedback and get others to chime in about tire wear issues with their own lowered CLKs. For the benefit of others, please provide specifics on your suspension setup, tires, wheels or other details (like accident damage) that might affect your results.
Car: 2002 CLK55
Tires: Michelin PS2 (225/45-17, front); (245/40-17, rear) - stock size
Wheels: Stock AMG Monoblock II
Suspension: Stock AMG dampers with euro-spec springs
Springs pads: 2 bump front, 1 bump rear
Properly aligned and balanced
No accident damage or bent wheels.
I do check tire pressure often and keep them around 35psi. I put on the PS2s about 15 months ago at 16K miles and currently have just under 24K miles on the setup, so about 8K miles total.
I can report that there have been no unusal tire wear issues and am getting even wear across the rear tires, as I did with the stock setup and original Michelin Pilot Sports. I hope to get an additional 8-10K miles out of this set before having to replace them. The tires have never rubbed.
What are your results?
Old Feb 16, 2006 | 05:43 PM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
I had a very aggressive alignment on my WRX with coil overs and -4 degrees of camber. Lowered 2" +. Handled realy well too!
The negative camber is not so much of an issue as the toe. With proper alignment and 0 toe you should not have excessive inner tire wear.
Owen
Old Feb 16, 2006 | 11:40 PM
wfoclk55's Avatar
'02 CLK55 ///AMG '05 Raven R1
Hey Chappy,
You quote your tire sizes both at 225 front and rear. Is that a misprint?
Old Feb 17, 2006 | 06:44 AM
Chappy's Avatar
AMG
Originally Posted by wfoclk55
Hey Chappy,
Sharp eye...thanks. My initial post was in error....the rears are 245.
....fixed!
Old Feb 17, 2006 | 11:36 AM
SoCalCLK's Avatar
2017 W205 C43 AMG
Car: 2002 CLK 430
Tires: Goodyear Eagle F-1 (235/40-18, front); (255/35-11, rear) - 18" Staggered set-up.
Wheels: 18" AMG Monoblock Aero II
Suspension: Stock OEM dampers with BRABUS springs
Alignment: Properly aligned and balanced
Notes: No accident damage or bent wheels
I believe that proper alignment and tyre pressure are critical. I bought this set up and have driven 17,000 miles on it. The Goodyears are exceptional in their wear life, comfort, wet-handling and low noise.
I keep 36 PSI all the way around.
Old Feb 17, 2006 | 11:58 AM
JamE55's Avatar
Out Of Control!
Looks like a fun thread so hope you don't mind me joining Chap?!
Car: 2002 E55 K S8
Tires: Bridgestone SO-3 Pole Position (245/35-19, front); (275/30-19, rear) -not stock size (pretty obivious lol)
Wheels: HRE 540R's Staggered
Suspension: Kleemann Speed Sensitive Shocks & Kleemann Springs
Springs pads: # 1 pad all around
Don't remember my psi but i think they're 30's front and higher 30's rear. Running on regular air but thinking about switching to nitrogen filled? Well see.
Note: The only tire wear i get is when my gas foot gets happy. LOL
Old Feb 17, 2006 | 02:40 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Car: 2002 E55 K S8
James,
I Think Chappy is Lookig for RESULTS from Mercedes owners that DRIVE the cars....
Oh Yeah....Did You READ this thread?.....CLK Owners......
Old Feb 17, 2006 | 02:51 PM
JamE55's Avatar
Out Of Control!
Originally Posted by MARK CUMMINS
James,
Good thing i drive mine then. lol Actually just read the Lowered part and ignored the rest. lol
Old Feb 18, 2006 | 11:16 PM
wfoclk55's Avatar
Does anyone know where I can get my '02 CLK55 lowered in the Southern Cal / Orange county area? I'm putting 19" wheels on next week. Still not decided which ones but, I'll post up some picks when I get it done.
Old Feb 19, 2006 | 01:51 PM
JamE55's Avatar
Out Of Control!
Talk to Sander! Shop is called The Wheel Supply. www.thewheelsupply.com They're in walnut. They do pretty good work. Their tech Pete is . Let me know what kind of 19"s you're getting.
Old Feb 19, 2006 | 04:20 PM
Chappy's Avatar
AMG
James,
ROFLMAO!
Old Feb 19, 2006 | 05:39 PM
wfoclk55's Avatar
Thanks JAM, I'll look them up on tuesday!
Old Feb 19, 2006 | 06:57 PM
Joel W Sanders's Avatar
02 CLK 55 AMG , Wifes 91 CE
I too would like to get my car lowered, new wheels 18in or 19in still yet too be decided. I am thinking of black centers since the car is briliant silver any one seen this combination?
Walnut seams a bit far from San Diego County ,though, it would give me an excuse to drive fast and see if I can avoid a speeding ticket.
I would expect that there should be a good shop in Orange county.
Thanks for any Info
Old Feb 19, 2006 | 08:28 PM
MPRESION's Avatar
On my 2002 CLK55 AMG, I was using the stock AMG Bilstein dampers with H&R springs. As well, I had #2 pads in the front with #1 pads in the rear. I was using 18" AMG Monoblock rims... 18*8 fronts with 18*9 rears... running Goodyear Eagle GSD3's... 225/40ZR18 fronts with 255/35ZR18 rears. No accidents, nothing. Oh yeah, and 10mm spacers in the rear too
Tire wear was pretty good... pretty even wear... no complaints here on that set up
Old Feb 19, 2006 | 09:04 PM
JamE55's Avatar
Out Of Control!
Welcome! Let me know if you have other questions.
I've seen that combo and it looks hot! Some might say it's played out just because there's a lot of them out there but nonetheless looks nice.
Old Feb 22, 2006 | 10:36 AM
JJMC617's Avatar
2004 CLK55
Hea
The dealership is a cheap way to have the car lowered. I think I was quoted 400 dollars for the Star Diagnostics
Old Feb 22, 2006 | 11:51 AM
Bullett's Avatar
2008 E63 AMG
Exactly the same as my setup....nice looking car....
Old Feb 23, 2006 | 11:48 PM
DMC's Avatar
DMC
2002 MB CLK55
Suspension and Wheels
Thanks for any Info
Shoreline Auto in Huntington Beach
