Resonator Delete on W209
#51
it is not a matter of safety regarding the secondary cats. i believe that any exhaust shop can be fined for permanently removing catalytic converters. why the hell would they put four cats on this car? i am perplexed.
for now i will just change the muffler to a magnaflow for a little more sound. i eventually i might swap out the two precats to high flow cats. i am not touching the two intertwined cats....weird and complicated to say the least.
thanks for posting the pics guys that has at least give me some time to plan out what i am going to do.
#52
thats the type of job that needs to be paid in cash, no reciept... All modern cars have at least 2 catalytic converters...
Usually it goes something like... Engine, exhuast manifold, o2 sensor, catalytic converter, secondary 02 sensor, secondary cat..., sometimes a resonator, muffler
Resonators are installed to make luxury cars more quiet... purely a fluff part...
Removing the cats, while bad ***, can also be obnoxiously loud, but with a muffler still installed, it might just make it sound really bad ***, one of you needs to bite the bullet so that you can get a sound clip of it... so everyone else can follow...
#54
09 335i 03 CLK55 AMG
Here is a picture of the removal. I weighted the whole thing and its 31lbs. This was replaced by straight pipes and a y pipe at the end. Car sounds like a beast and its def a bit quicker off the line. Will take a picture of under the car possibly tonight, my brother has the car or else I'd do it now.
![](http://img524.imageshack.us/img524/1958/picturerk5.jpg)
#55
E55 AMG + Mustang GT
Do you have emission tests up where you live? If not, then you can remove the cats and not worry about it. Go to any performance shop and they will be more than happy to replace it with a straight pipe instead of a cat. What I would suggest though is to get 2 universal high flow cats and replace your secondary cats with those. Replacing the secondary cats will make the car louder.
#56
#57
1 Post
03 CLK 55 AMG, IMCO muffler/Magnaflow tips, KW V1 coilovers, 19" Petrol Metrix Wheels
i am not touching the secondary cats. i think an aftermarket muffler: magnaflow, dynomax, borla, flowmaster, etc. will achieve the desired result. i will have mine done in the next couple of weeks. i will try and post some pics and a sound clip. i am not wanting a roaring monster (i have that with my GTI - 3in exhast under 25lbs of boost).
#58
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
After reading this thread I decided to remove my resonator to give
it a little more sound.
WOW, great mod!! easy and fast, took 20 mins and 70$ at the muffler shop.
The sound is great, a little louder but not to much
It's worth it !
PS: I have a CLK 55 AMG 2005
(with stock quad exhault)
It's worth it !
#59
Ok
Guys as some of you know i have done my own creation,of what i wanted my system to sound like.
I have left the secondary cats in place,trust me,no need to remove those.
Right after the cats,i have put on two mufflers/cans in place,they were welded on(right after the cats)from there there's 2 mandrel bent pipes that made their way to the left and right side of the car,two tips were welded on on each side.Yes the bumper needed to be cut into,but it was dine clean and nice.
Here's the result:
http://www.youtube.com/watch?v=fQ5LCMtrNh8
http://www.youtube.com/watch?v=azRrkCk6xKo&NR=1
http://www.youtube.com/watch?v=BL_Fc078CsE
Here's the result:
#60
clk 500 (wifey's); 350Z roadster (daily driver); 350Z coupe (track car)
#61
it becomes a legal issue,and if a shop removes a cat they need to replace it with another.
Unless you know a shop that wont care.Or they just take your cats off,they clean them out and put them back on.And then also you need to have someone that will smog it for ya.
#62
It's worth it !
It's worth it !
#64
2003 CLK240
Hi,
I'm thinking about deleting the second cat and just welding a straight pipe in insted. Mine is a V6 but wit the factory sistem it's very muffled. I know it's not going to sound like a 55 or 63 but if it gets a bit louder that might just brighten my day a bit
