Road course track tires on a W208...Michelin...Hoosier...Kuhmo...Avon...Yokoham a?
I've looked at the reviews, etc. on Tire Rack, and they all seem to favor the Michelin Pilot Sport Cup. I could justify the expense of these if they lasted 40-50 heat cycles.
Anybody with real-world feedback in a W208 car to chime in?
One other thing: On occasion, I may want to drive to the track with the tires pre-mounted, so this would be a purchase consideration as well.
How often do you plan on getting to the track. I would definitely suggest you try the RA-1 first. If you can find some Kumho Victoracer (V700) that are slightly used you could get a feel for rcomps on the cheap that way. Also, I have some somewhat busted V710s that you can pretty much have if you want to try them as well.
http://www.toyoad.com/proxesra1_specs.html
They get better and better with age. For the fastest tire the v710 or the hoosier are the best. Down side is in a heavy car and if you are agressive they will go Fast. I use the 275 ra1s all the way around. I put the rears wheels in the front with a 5m spacer. Your car has a different front set-up and Ive been told you may have more room. Not positive.
the v710 are wider than the RA1s so 245 275 on 7.5-8.5.
On the street or autox with street tires its tough to beat the yok advan neovo's.
I run 235 265. I just did a porsche event and I ran the 275 ra1s in front and the 265 yoks in the rear (usually not reccommended to mix street and race but the yoks are close to the ra1s). I was actually able to get the rear to transion nicely. Usually it pushes (understeer) pretty bad. I also was racing a spec 944. I was a few seconds faster in the clk and faster than 90 percent of the porsches too. I would also suggest a stiff front swaybay to help spirited driving tire wear. I have the H and R. Down side is you feel alot more bumps. Upside is at leat 50% of the bodyroll is gone and the corners are so much more fun. You could comprimise with an amg front sway bar.
good luck
i had yokohama a032r on a daily driven e36 m3 and they were the ****, when they got hot the grip was unbelievable, never tracked it (the canyons are my racetrack
). i went into a few corners too fast (way too fast, on 1 occasion i forgeot there was a corner
, i was probably not sober
), i slammed on the brakes (stock) and the car shed speed like
to the power of 100000000 (lack of better word)
