Kleemen S/C Kit
Old Sep 25, 2002 | 09:42 PM
jrod178's Avatar
Kleemen S/C Kit
I was wondering what was included in the Kleemen S/C kit. From the pictures I saw it seems to be a screw?? type blower? From my experience Screw or Roots types have always been the least expensive. Why is the kit running 17k. I know everything for MB's is going to be expensive but Lingenfelter is making the same kind of blower kit for the vette for like 6k and a company is making one for the vipers for 6k. Not trying to be cheap, just trying to get a better understanding of the markets for modifications.
Old Sep 25, 2002 | 11:29 PM
Petie's Avatar
2000 CLK430
Re: Kleemen S/C Kit
Its hardly bolt on, takes quite a bit of install time. plus you are looking at a S/C running low boost putting a car from 342 hp to 515hp, the lingenfelter isnt doing that at a boost of what? 7? 8? someone help me there....i believe Kleemann still has a patented intercooler, it is one of the most advanced S/C on the market with very little stress on the engine, thus the price....you get what you pay for in my opinion...
Eric
Old Sep 25, 2002 | 11:41 PM
jrod178's Avatar
Alright, I just wanted to make sure it wasnt just a bolt on and people were getting gouged because they own MB, but if its a quality unit, then thats great. How long is a typical install? Does it require any internal engine work? Heads, pistons, rods, etc.?
Old Sep 26, 2002 | 12:43 AM
Petie's Avatar
2000 CLK430
i believe you give up your car for about a week for install, for test purposes and computer remapping and what not, i dont believe any major components of the engine are changed, although new cams, headers, and what not just means more HP!!!, i wish i could say more, Mach430, where are you???? lil help bud....
(Mach430 can answer all your questions as his car has the Kleemann, throw him an email)
Old Sep 26, 2002 | 07:51 AM
Cory @ Kleemann's Avatar
Former Vendor of MBWorld
The KLEEMANN kompressor system is a "bolt on" meaning there are no internal or computer modifications necessary. typical installation time is 2-3 days, maybe longer depending on if you would like to have your vehicle dyno tested before and after. The vehicle will be driven approx. 100 miles so the ECM has the chance to adapt to the added air and fuel demands. HP=530 Torque=490 lbs/ft.
If you are looking for the same power gain from renntech, be prepared to pay in excess of $30,000.00.
The kompressor is a lysholm type twin screw supercharger. The most efficient supercharger on the market today. It is combined with a laminova type air to water intercooler. The intercooler alone has the capability to cool the charge air 85-95%, depnding on conditions. Boost is set at a conservitive .5 bar. This system is engineered to the same quality standards as MB. If you would like to out run your buddy's Viper at the drag strip, this is the system for you.
Old Sep 26, 2002 | 09:04 AM
jrod178's Avatar
Thanks, does anyone know what exactly is included in one of these kits? New injectors? New fuel system totally? Thanks
Old Sep 26, 2002 | 10:03 AM
The kit contains the kompressor unit, and all necessay components for a complete installation. The stock fuel injectors are retained, as well as the stock fuel system. The extra demand for fuel is handled bya KLEEMANN fuel pressure regulator which increases fuel pressure depending on the amount of boost that is present in the engine. Mercedes-Benz fueling systems constantly chases a lambda signal (O2 voltage) after every combustion cycle. The ECM then analyzes the signal, determines if A/F ratio is correct then adjusts injector on-time accordingly if the ratio is not satisfactory. Increasing fuel pressure allows the injector to flow a greater amount of fuel, thus compensating for the added volume of air. The air/fuel ratio will be the same as a stock engine.
Old Sep 26, 2002 | 12:33 PM
jrod178's Avatar
Thanks so its the kompresser unit, necessary brackets for mounting, fuel pressure regulator and ECM tuning. What about intercoolers? Anything else? Has anyone ever installed one themselves or known someone to do it, I remember these types of blowers being fairly easy to install? Does the car retain the stock radiator and fans?
Old Sep 26, 2002 | 02:08 PM
As I stated in my last post, There are no ECM modifications necessary. The kit comes complete with all necessary hardware, fastners, radiators, hoses and brackets, etc. The installation can only be done at a KLEEMANN authorized dealer. KLEEMANN does not sell directly to the client. E-mail me at info@kleemannusa.com for a list of authorized dealers in your area if you are interested. I can also answer any additional questions you may have.
Just a side note: this is not a honda or chevrolet supercharger kit. This is a highly engineered and tested system that is CARB certified, and designed with the quality and dependability that Mercedes-Benz engineers into thier vehicles. The installation take several fairly specialized tools that most individuals, let alone shops will not have. They are not uncommon tools, just ones that are not needed for everyday use in a shop or garage.
Like I said, please email me with any other questions you might have about the KLEEMANN kompressor system. I will be happy to answer all of your questions.
Old Sep 27, 2002 | 10:08 PM
w208amg's Avatar
clk55
what about...
fuel consumption, engine wear, suspension needs. I would love to get one but I still am hesitant.
Old Sep 28, 2002 | 12:51 AM
Re: what about...
Fuel consumption will increase. You can't get around that when increasing power by 50%. On average, 18 MPG with conservitive driving and 10 MPG if you mash the skinny pedal after every red light. (based on an E55)
Engine wear will also increase but only to the tune of approx. 15-20%. Again, something you can't avoid when adding 50% more power. So, if your engine was designed to last 200,000 miles, you might expect it to last 170,000 with the KLEEMANN system.
Suspension upgrades are not needed. However, to get the best performance times, an upgraded suspension can only help.
Old Oct 1, 2002 | 01:53 PM
Sleestack's Avatar
Re: Re: what about...
It was my understanding that Kleemann tests showed only a 3% increase in engine wear, however, I don't know if that holds true with the newer applications.
Suspension upgrades are needed not because of the SC, but rather, because stock Mercedes all come with a geriatric setup.
I would recommend upgrading your brakes.
Old Oct 1, 2002 | 02:27 PM
Larry Sonsini
Guest
Posts: n/a
Re: what about...
haha, funny sleestack, but so true. Even the CLK55 begs for suspension upgrades. As for the brakes, the stock ones are fantastic on stopping power. However, if you do plan on tracking the car at all, you'll want to move up to a big brake kit to prevent fade. I didn't run into any fade issues over the weekend at willow, however, I'm not exactly the hardest driver out there either.
Old Oct 1, 2002 | 03:51 PM
Re: Re: Re: what about...
Sleestack-
I like to give maximum numbers, as to not be deceptive. You might have a 3% increase in wear if you drive like grandma on her way to church on sunday. 15% would be hammering on your engine constantly- holding it in second or third gear at redline. Not likley, but conservative numbers are safer to quote than numbers like Renntech quotes. You are absolutly right on with the "geriatric" suspension. my point being that you don't have to upgrade your suspension when one gets our kompressor installed. Most people do though. Why not eh??
Thanks for mentioning the brakes. How do you expect to handle 50% more power if you use the small, less grippy brakes? Again, an upgrade not needed, but highly recommended for saftey and fun!
Can't wait to hear about the results of your project!!
Old Oct 2, 2002 | 03:34 AM
Shine's Avatar
Thumbs down
Wrong concept up there !!
Allow me to look insight of C32AMG & C320.
Different brake & suspension setup by "FACTORY" engineers
They're experts to determine what should be upgrade or not.
These two cars are 50% hp gap each other !!
Then look at those C32 guys, none of them feel the needs
to downgrade the factory setup to be like C320 because
the stock C320 is good enough, while few enthrusiasts even
find upgrade solution for their interests.
Once we decide the hp upgrade,said, 50% , they're in totally
different leagues, you may find the budget is constraint
well, try to optimize your mods in every penny.
I know those Turbo Civic or Subaru boys are happy upgrading their turbo,as larger as possible,then ran out of money....
left the chassis & brake "stock", God ! hope they
know what they're doing to themselves & other innocent ppl.
Old Oct 11, 2002 | 01:33 PM
stormy's Avatar
CLK55 Cab
I think we all can agree the Kleenman is a well built supercharger and should be priced somewhat more, but 18k that is a lot of $$ for 150hp. I can Assure you there are probably several CLK owners that have the $$ and would love to put on the supercharger but have a hard time justifying the cost.
It's like the Tyco guy and the $6000.00 shower curtain. Maybe we can get a group of CLK owners that are interested and see if we can get some sort of volume discount. Because I am sure the price is also set due to the # they produce.
Just a thought.
Old Oct 11, 2002 | 09:08 PM
Just a thought.
Once you experience a KLEEMANNIZED car, there will be no question in your mind it's worth every penny. You truly do get what you pay for. By the way, it's in increase of 175. 205 increase if you tell the ECU your in europe and you are using 97 Octane gas!
$107 per HP?? Hmmmmm, can you say "smokin good deal"?
Old Oct 12, 2002 | 12:36 PM
w208amg's Avatar
clk55
group buy, I'm in..who can look into this?
