SpeedTuningUSA Chip Purchase & Dyno To Come
Old Mar 23, 2007 | 12:22 PM
ashutt's Avatar
2005 SL600 by SPEEDRIVEN
Ok, I have researched the different chips available for a 2001 CLK55 AMG and determined that based on their representations they all appear to be about the same in their improvement numbers and what they can do, which includes (1) increase HP and TQ, (2) increase the redline and (3) remove the VMAX speed limit of 155.
After speaking with Oliver at SpeedTuningUSA, I have decided to try their 93 octane ECU reprogram. I will have the car dynoed after driving it hard for 200 miles so that the ECU can adjust to the new program in order to see how the numbers improve, or not, over stock. The ECU can then be adjusted again if needed according to the A/F ratios and RMP in order to fine tune the program.
I believe that we can verify whether this reprogram lives up to the claims of an increase in stock hp from 342 hp to 373 and a stock TQ of 376 to 391. For the price, it would be a big bang for the buck at $325.00. Most likely after a retune the program could be more refined for the general masses- at least the 2001 and 2002 CLK55 crowd.
I will request the following modifications:
(1) Redline moved from 6,000 to 6,400 (may only be valuable in lower gears)
(2) Performance increase based on 93 octane
(3) VMAX speed limitation of 155 removed (this will have to be tested)
I will keep you posted. If the chip works as claimed or even close to it because each car is different (i.e. I have green filters), then I will try and organize a group buy for those interested. I believe this will help other chip resellers compete more competitively in this space. However, if the chip reprogram doesn't work as claimed, I will certainly make every member aware of this fact.
Old Mar 23, 2007 | 12:58 PM
ItalianStallion's Avatar
R35 GT-R, EvoX
Awesome. I also have the SpeedTuningUSA ECU upgrade for my CLK500. I found there was definitely an increase in hp/tq and I was able to go past 135mph. I've had it for about a year now and I'm not sure if my ECU is back to stock because of the numerous visits to the dealer and the tuning for NOS. But I could definitely feel a nice acceleration and response increase as soon as I got the file uploaded.
Good luck
Old Mar 23, 2007 | 01:52 PM
blackbenzz's Avatar
haters crazy
Excellent! Finally someone is going to dyno before and after. I felt a nice gain on my CLK430 but it was according to my butt dyno which needs calibration, lol. I had organized a group buy with Oliver before. Ask him if he will still give you the discount through the group buy Ahmad put together for mbworld. It wont hurt to try. Keep us posted!
Old Mar 23, 2007 | 03:26 PM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
I need to redo my ECU cause I'm having problems with the Evosport pulleys and the ECU don't seen to get along with each other.
Old Mar 23, 2007 | 03:46 PM
ashutt's Avatar
Who is the issuer of your performance chip? In speaking with Oliver at SpeedTuning USA, their custom programing is only $500 to $700, depending on what you like.
For example, I am considering a socket where I can swap a 93 octane chip and a 100 octane chip for the track- for a total cost of $700. That is awsome if you ask me.
You may want to give Oliver a call [(301) 421-9464] and mention that you spoke with me (Allan with the 2001 CLK55 AMG) and he will remember our whole discussion yesterday and today regarding the CLK car and what it is we want done. You can then inquire about a more custom program for your car with its specific modifications. If you speak with him, keep us posted on the developments. Good luck!
Allan
Old Mar 23, 2007 | 04:09 PM
acb3nz's Avatar
Allan
Oliver and hes local for me It takes me 20 minuts to be at hes shop. He has work on my car a long with blackbenzz car. He also told me that i might need a better program with more fuel. The downside of it is that my ECU needs to be ship to Germany to get it done.
PS. I jst got off the phone with Oliver andhes gonna fix it he has the new software for me so im good to go. I always use hes chip and it works like a champ.
Old Mar 23, 2007 | 05:03 PM
Chappy's Avatar
AMG
Allan,
Have you had your car dynoed before? Both times I had mine done at the AMG Meets here in ATL, the car kept downshifting. I hear there's a fuse or something that can be removed, but my understanding is that it throws a code....
Check with "Ted Baldwin" about this as he's got a W210 E55 on the dyno several times.
Old Mar 23, 2007 | 05:08 PM
ashutt's Avatar
Hey Chappy,
No, unfortunately, I have not dynoed the car before. I was going to ask how to perform this since I understand it can be an issue. In fact, I was going to ask you since I see you have dynoed your car. Do you believe you didn't have a proper dyno then due to the downshift?
Old Mar 23, 2007 | 05:27 PM
Chappy's Avatar
AMG
Hey Chappy,
The dyno operator just hit the ESP off button on my runs. I was within a couple hp of rsr911's CLK55, so I knew it wasn't much of an issue. Plus, I wasn't trying to compare before and after dynos with performance modifications, so I had less worry about being so precise....Owen knows too well about this lol...
However, we don't have dyno mode to just switch eveything off. Blackbenzz may be another member to ask.
Old Mar 23, 2007 | 05:45 PM
blackbenzz's Avatar
haters crazy
I couldnt get my car to dyno right. I did pull the fuse (dont remember which one it was) and it cut EVERYTHING including ESP and ABS off. It didnt make a difference for the downshifting on the dyno though.
Old Mar 23, 2007 | 05:54 PM
Ghostrider's Avatar
01 CLK 430
Did you select a gear or did you just leave it in drive?
Old Mar 23, 2007 | 05:56 PM
Ghostrider's Avatar
01 CLK 430
Allan
Oliver is the man!!! Said he would do a custom tune for my car too....
Old Mar 23, 2007 | 05:58 PM
blackbenzz's Avatar
haters crazy
Well I wasnt driving it on the dyno but I told the guy to select a gear and he said he did.
Old Mar 23, 2007 | 06:06 PM
ashutt's Avatar
Hey Ghostrider,
Did you just speak with Oliver? What type of custom work will you do? Gotta love modifications! My biggest problem is getting 93 octane!
Old Mar 23, 2007 | 06:24 PM
Ghostrider's Avatar
01 CLK 430
Hey Ghostrider,
Yes, a very pleasent fellow. Its just like what you are wanting (and I wish we had 93 octane here) but tuned to my car with my mods.
I want to do more, like a bored out throttle body but not sure if that would give me anything, got bet to the punch on PTE's cams. Thing about it is if you get to far into the NA mods you might as well pony up the dough for a supercharger.
Old Mar 23, 2007 | 11:36 PM
acb3nz's Avatar
Yes he is
Old Mar 24, 2007 | 08:37 PM
Ghostrider's Avatar
01 CLK 430
They tried that when when mine was done, but eventually they just left it in drive. The ones in drive gave us our best runs.
Old Mar 25, 2007 | 05:32 PM
rsatmans's Avatar
None
I have also had the ecu done by oliver i cant wait to see the dyno results on your 55.
Old Mar 25, 2007 | 07:59 PM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
It was an interesting day at the dyno. My car performed perfectly. No issues.
Chappy's car kept down shifting. No clue why. Our cars dynoed with in 2 hp and 3 lb ft of torque. So we did get good numbers for both.
The W211 E55s we dynoed were with in 5 hp and 5 lb ft of tourque. I think we had 4 of them. Again good numbers.
-O
Old Mar 25, 2007 | 09:57 PM
ashutt's Avatar
So, you just put the car in drive and let the car do the rest for the dyno?
Please post the dyno numbers so we can see some baseline figures. I should have a dnyno by the end of April so within 30 days or so. Need to drive the car with the new reprogramed chip first. Should have the ECU back on Wed. or Thur.
Old Mar 26, 2007 | 09:39 AM
rsr911's Avatar
Ashutt,
If I remember correctly they turned off the traction control and shifted my car manually. However even in manual mode the car will down shift from 4th to third under heavy load like a dyno run. Mine didnt but Chappy's did.
My car put down 301.5 hp and 318 lb ft of torque at the rear wheels.
I only got 1 run and the dyno trigger broke. Everyone else got at least 2 or 3 runs. The cars did better on the second runs after the computers had a chance to adjust.
-O
Old Mar 26, 2007 | 11:58 AM
ashutt's Avatar
Chappy,
Did you end up with similar dyno numbers to your previous ones of:
WHP: 304
TQ: 321
Old Mar 26, 2007 | 12:17 PM
Chappy's Avatar
AMG
Chappy,
WHP: 304
TQ: 321
I've had my car dynoed twice:
First time: 290WHP, 313TQ (April 2005)
2nd Time: 304WHP, 321 TQ (November 2006)
Two different facilities (but same equipment - Dynojet), ambient temps and humidity were different, the car was more broken in the 2nd time, etc, etc. Both times I had issues with downshifting, but managed one "clean" run at the first Atlanta AMG Meet in April '05.
Honestly, I've only dynoed my CLK for fun (my engine/intake/ecu is still stock).....but it seems I've gotten a lot of 'mileage' out of beating Owen by 2hp.
I know that it's strong (for a stock "55")....13.3 @ 109.00 in the quarter with a 2.1 60' on the original air filters. My buddies dad is an ex-pro drag racer and calculated that I was 360-365 at the crank with those numbers, based on the weight of the car. AMG says "stock" hp at the crank is 342.
Old Mar 26, 2007 | 12:22 PM
blackbenzz's Avatar
haters crazy
^ Impressive! Cut that 60' down and your ET will be much better! Maybe throw on a set of d/r's for fun I think you can run 12's
Old Mar 26, 2007 | 12:24 PM
Chappy's Avatar
AMG
lol...I've heard emptying my trunk helps too...
After the track day in April, I might be enticed for another mod *cough* Quaife *cough*
