Correct. Throughout the model years, the C55, SLK55 and CLK55 engines are all the normally aspirated versions of the engines found in the E55, CL55, CLS55, SL55, etc.
Quote:
Bro you're killin me but I'll tell you again. Originally Posted by blackbenzz
Good info. I'm actually replacing my resonator with a y-pipe tomorrow (for sound and weight saving), do you think there is any performance to be gained by switching my stock secondary cats to race cats or even deleteing them completely? I have kleemann headers and eisenmann race muffler. TIA
If you delete your secondary cats you will throw a CEL. You will be freeing up some power by replacing the stck 400cell secondary cats with some higher flowing Stainless Steel 200cell cats.
PS I will be replacing my stck muffler though with this:
http://vibrantperformance.com/catalo...f75d53ca32b94e
in all black or this in stainless steel:
http://www.prostreetonline.com/pnsku/vib-1043.asp
to reduce the weight that the stck AMG muffler leaves me with.
Quote:
btw, the W209 look way better than ppl give them credit for.
The W208 is a classic body style that will last forever. I only hope the W209 can come close to that. But it will never look better than the W208. I've had both body styles so I know.Originally Posted by Quant
lets be honest, we all wish that our cars had a supercharger. 500HP and 500+TQ in a car that weighs 3500-3800lbs. that would be almost CLK DTM level
Don't get me wrong. I still love my W209.
I love my 208!!! The aggressive body lines and the stout squared up trunk does it for me. I also like the newer bodied 209s. Its a toss up both great looking cars with amazing power!!!! Quick question though. Isn't the stock exhaust system diameter 2.5"? Where would I be able to find some 200 cell high flow cats? Does any one recommend stepping up to a 3" system from the the "Y" back vs. the stock system.
I just replaced my resonator and secondary cats on my W208 CLK55 with a Y pipe and have yet to throw a CEL... I only have about 30 miles on the new setup though. Originally Posted by ProjectC55
Quote:
Where did you get the y-pipe?Originally Posted by craigrhyne
krispyw208- after the resonator it is 3" piping back to the muffler
Carl- My muffler is an eisenmann race muffler which is supposed to be lighter than the AMG.
I was told that the factory size on an 02 clk 55 was 2.5" not 3".
ExploreQuote:
It is dual 2.5" up until the resonator, then its 3" back to the mufflerOriginally Posted by krispyw208
ok thanks. What about replacing the secondary cats with high flow's or put in the Y pipe..
I went down to our local performance shop here in Lubbock Texas and had them weld up a dual 2.5" inlet to 3" outlet y-pipe. Cost $100 and took about 45 min.Originally Posted by blackbenzz
Where did you get the y-pipe?krispyw208- after the resonator it is 3" piping back to the muffler
You can also use 180 deg mandrel bends to weld up x and y pipes like this:
I have purchased bends and pipe from these guys before: http://www.magnumforce.com/ubend.asp
Before adding more power, I'd prefer to have the K2 V.2 and Quaife ATB installed....Originally Posted by Quant
Spend some time on a wet track and you'll see my point.
Quote:
What if you already have KW v.2, Kleemann LSD, and Brembo GT front BBK?Originally Posted by Chappy
What if you already have K2 v.2, Kleemann LSD, and Brembo GT front BBK?
....the obvious choice....a CL65!
I'm just getting as much seat time as possible, so as improvements are made each step allows me to excel as a driver. Frankly, my remedial skills have yet to master the stock power on tap and I'm working on car control (on street tires) before I move to significant performance improvements.
whats a K2 V.2?Originally Posted by Chappy
Before adding more power, I'd prefer to have the K2 V.2 and Quaife ATB installed....Spend some time on a wet track and you'll see my point.
i agree, getting an LSD is very important. but i'm willing to bet that is a SC and an LSD cost the same, u would get the SC. just a hunch
Quote:
Its KW v.2, KW is a company that makes suspensions and the V.2 allows for rid eheight and rebound adjustabilityOriginally Posted by Quant
whats a K2 V.2?
Quote:
Coilovers Originally Posted by blackbenzz
whats a K2 V.2?i agree, getting an LSD is very important. but i'm willing to bet that is a SC and an LSD cost the same, u would get the SC. just a hunch
.....or just ask mbenzman to take me for a spin once in a while. $4/gal gas isn't going to make me jealous of a blower.
Not really....I take that back!
Quote:
They arent true coilovers for our W208's thoughOriginally Posted by Quant
Coilovers
Quote:
The W208 uses a separate spring/shock setup instead of a McPherson strut. The "coilovers" for the W208 are really just a matched shock and spring.Originally Posted by Quant
Quote:
ok, thanks.Originally Posted by craigrhyne
btw you have a really nice car collection
Quote:
It's actually about 2.75 inches stck after the reso.Originally Posted by krispyw208
Quote:
Don't worry it will!Originally Posted by craigrhyne
Quote:
Yes I did it. You'll fall in love with your car all over again. You'll notice.Originally Posted by krispyw208
