After market Audio/Video
Bob
A guy I found in my area told me if it is then i wouldnt be able to run the factory subs? is it possible to just change the head unit ?
the 2 in the back behind the rear seats
Your CLK looks clean as hell. I'm looking to add a navi system. I want to go with a Kenwood and like the others here I was told that the whole system would have to be upgraded due to the Fiber Optics in the car. My question to you is:
1. How much did it cost for your Navi system and speakers (Including Install)
2. Why did you go Alpine? Was it a personal choice? Do you feel they're better or both?
3. How does the 19's feel on the road?
My bad you do have a Kenwood system
Silly me. In fact, I believe that's the one.
Thanks for the kudos!!
When I was buying all the parts, all the shops told me that I would need to replace every thing, due to us having fiber optic. I did not have to upgrade anything extra. All I did was replace the headunit with a Kenwood DDX7015, and I added a Kenwood TV Tuner. I left the stock bose speakers in the car. All the shops told me that I would have to replace them, but I didn't not have to replace them. With the Kenwood headunit, the speakers sound 100 times better than with the stock head unit.
1.) I don't remember the exact prices, as I bought the stuff about 2 years ago. The Kenwood DDX 7015 head unit was around $800, navigation addition another $200 from Kenwood, and the TV tuner was another $200+
All of the installation was free, as I installed it all with a good friend of mine thats an audio genius. He's the one that told me not to listen to the shops that told me that I would have to upgrade everything...
2.) Like you said in your later post, I have the Kenwood. The latest Pioneer is looking very good.
3.) I have the 19's with H&R sport springs, the ride is rougher than stock, but I love it this way. It is still soft enough where going over bumps won't hurt you. It feels like the car is riding on rails. The handling also improved.
http://forum.hifimobile.fr/viewtopic.php?t=7844
I am keeping the original COMAND system but am adding an Alpine DVD player that will connect into the HU as an auxilliary to the MB TV. I was having too much fun with the original COMAND (the redundant displays, the linguatronic, the telephone in the armrest, the British lady who tells me where to go...) to start over with something else. Still, I might add a second screen and bluetooth sometime down the road...i am waiting for digital radio to show up in Europe. In any event the heavy work is done -- the sound insulation, the new speakers and the Brax amp.
Sweet! I would like to keep the orginal COMAND system as well so that I could control the radio from the steering wheel. However, I want the new Kenwood DNX 8120! From what I've read about it so far it's probably one of the best DVD/Navigation units out. The only problem is that it doesn't fit my car
according to Crutchfield's website. Maybe because the monitor is 6.95' inch wide? Would anybody know what the biggest size monitor could fit?
So you changed the head unit and a tv tuner and still was able to connect the 2 bose speakers in the back?
cuz my guy told me he will be able to connect the front speakers no problem just the back 2 speakers will be disabled. and without those 2 (bass) the sound will be very hollow.
maybe i just need to find another audio/video guy
Also, when replacing the head unit, you will need to get a new dash kit around the radio, as whichever head unit you put in won't be a perfect fit. For a 03-04 CLK, nobody has one listed that fits, but I bought one for a 01-04 C-Class and just cut the middle part, and it fits perfect. http://www.installer.com/item/displa...php?it=99-8711
For the 05+ CLK, they do have a dash kit. Again, just cut out the lower part so your double din head unit can fit.
Yes, I have the 2 speakers in the back working, and I also added a pair of subs in the back. Those 2 back speakers are definitely working though. As mentioned before, the only feature I lost was the steering wheel controls for the radio.
http://cgi.ebay.com/ebaymotors/PIONE...spagenameZWD1V
if you want your steering wheel comands (theres a diff between 03-04 w209s and 05+, so i'm not sure which this fits. if you search forum, you might get better answer).........oh just to clarify again, you changed NOTHING else except the headunit, and it worked fine?
I just used a RCA converter on the signal going to the factory woofer in the rear deck.
works great, just remember to take out the bose "audiopilot" mic above the rearview mirror, to prevent "feedback".
pm with any questions.
I'm still confused as to which wiring harness to use. Can someone tell me which one? Does the Factory Bose Amp have to be bypassed (meaning harness #2 below)? I'm looking for the least amount of work/re-wiring as possible. Also which two wires on the harness needs to be modified and modified as in ???
Help.
"Amp Integration plug - Mercedes C230 C240 C320*Fits models w/Factory amp. Does Not work if you are planing to remove the factory amp and not use it."
"If you are installing an aftermarket radio in your car you need this harness."
Mercedes C230 C240 C320 Radio Mounting Install Dash Kit (no clk listed, cut out middle plastic piece):
Import to Domestic Antenna Adapter:
