Help please...
Only [ast problems are gas guage stopped working. (i plan on having both fuel sending units changed shortly)
Heres the current problem:
I entered the freeway at a pretty good rate. (kinda stomped on it). 2 miles later at my exit, my CEL came on, but car was running fine. When I got to stop light, car was stumbling in idle. Continued driving and car smoothed out when out of idle. Stopped car again, idle was worse. Then car decided not to start. (Car would start sometimes, but would run real rough and then die). No previous occurances at all mind you.
It almost acts like it is out of gas, of course that will be my first objective is to put some gas in just to make sure. (I dont believe that it is empty)
I ordered a crankshaft position sensor as a precaution tonight, it should be here day after tomorrow.
Questions:
1) Could running out of gas actually throw a CEL? I will read codes tomorrow, but maybe cause a misfire or a fault MAF if its not getting adequate fuel at the time of running out?
2) I've read that others have had very similar experiences and have changed the CPS to fix. However, their problems seem to go away when engine cools, mine does not. Is it possible that the CPS **** the bed completley instead of slowing going bad as most have described?
3) Being as I already have faulty fuel sending unit, I go on resetting the trip odometer to time my fill ups (havent had a problem yet). I just fill up when my trip gets close to 250. Is it possible that this problem is progressive? ie: The sending unit telling the pump to stop when Im not really full. Therefore, I actually did run out of gas because it never completely filled?
4)Anyone know a reliable INDY in the bay area, NorCal?
5) Any suggestions would be greatly appreciated.
Thank you all very much.
John
Questions:
John
http://www.autohausaz.com/search/pro...0Mass%20Sensor
There are some instructions how to remove the MAF yourself if your interested I just have to find the weblink first. Good Luck!
Read the codes from the OBD II, they were for cyl 1, 5, and 6 misfires. I cleared codes and they returned. The car would then return to normal sporatically and then the misfires would return.
Any thoughts? I've pretty much ruled out plugs, wires, coil packs as I cannot imagine that much equipment failing at the same time.
CPS? MAF? ECU? Timing belt? Vacuum leak?
gave me some pointers on what to check etc. Sure enough I went under the hood and took out the old MAF..cleaned it with some CRC stuff, let it dry and revved it up...but the problem was still there. Then I went to go get a OBD ll code reader....got my code and sure enough it was the MAF. Cleaning it didn't work for me as it did for others so I bought a new one from autohausaz.com. Removed the old and installed the new one and haven't looked back since.
Now it could be something else and perhaps a lot worst but for the cost and the symptoms that you have I'll say check that first and foremost. Good luck with your decision
I ordered the CPS, MAF, and fuel filter last night. I would rather 'shotgun' these parts in prior to a dealer visit. Relatively inexpensive with a high mortality rate anyway. I'll call it preventative maintenance. Later on I plan on quadruple checking for vacuum leaks or loose connections and the like.
Ive seen intermittent problems too many times (Aircraft Mechanic by trade) to start jumping up and down, but so far so good. I will update in a few days. I still plan on checking my fuel pressure at the rail to verify adequated fuel delivery. Thanks again, Martymar
Looks like the MAF crapped so hard it didnt even code itself.
John
(aside from any major issues). I'm glad I was able to help. Other guys in this forum has helped me out tremendously so I had to show love back.
