Preventive maintenance
Can anyone recommend a maintenance schedule for CLKs to help them last longer? Things that can be fairly easily done yourself, like changing the oil at 3,000 miles.
I saw this, but I'm not sure which of these I could/should do myself.
http://www.autohausaz.com/mercedes-a...s-tuneups.html
When I replaced the M5 timing chain at 160,000 miles it looked virtually new inside so the long-ish interval didn't seem to hurt anything. It was also using about as much oil at the end as when we bought it in '89.
I would also plan on changing transmission and final drive oils every 40-50,000 miles, using OEM ATF for the transmission and Mobil 1 or Redline for the diff.
I replace coolant hoses around 80,000 miles, as I prefer to pick the time and place. I've always changed coolant every 40,000 miles, but with the new OEM coolant I don't know if that's necessary any longer.
I don't know how mechanically inclined you are, but with the exception of the ATF service, I do everything I just listed. None of it is very difficult if you have the correct tools.
Thanks.
While the wheel is in the air, you can check to see if there is play at 9 and 3 o'clock. That points to either wheel bearings or tie rods.
To check the motor mounts, pull the car up on ramps and look at them. If they have stains like fluid leaked from them, it's because the fluid leaked from them.
At that point, you need mounts. Everyone is different, but I'd never change a *single* mount. I change them in pairs. When one mount is dead, the other isn't far behind.
At that point, you need mounts. Everyone is different, but I'd never change a *single* mount. I change them in pairs. When one mount is dead, the other isn't far behind.For ball joints and tie rods I usually take a large pair of channel locks, also called water pump pliers for some reason, and squeeze the joint. Any movement at all means that the joint is bad. You can do this with the front end up in the air or on the ground in the case of tie rod ends.
